redis作计数器
小鲍侃java 发表于 2021/09/10 23:45:51 2021/09/10
【摘要】 插入 @Override public void incr(@Param("id") String id) { ValueOperations<String, Long> operations = redisTemplate.opsForValue(); operations.increm...
插入
  1. @Override
  2. public void incr(@Param("id") String id) {
  3. ValueOperations<String, Long> operations = redisTemplate.opsForValue();
  4. operations.increment(id, 1L);
  5. }
获取
  1. @Override
  2. public void sincr(@Param("id") String id) {
  3. System.out.println(getIncrValue(id));
  4. }
  5. public long getIncrValue(final String key) {
  6. return (long) redisTemplate.execute(new RedisCallback<Long>() {
  7. @Override
  8. public Long doInRedis(RedisConnection connection) throws DataAccessException {
  9. RedisSerializer<String> serializer=redisTemplate.getStringSerializer();
  10. byte[] rowkey=serializer.serialize(key);
  11. byte[] rowval=connection.get(rowkey);
  12. try {
  13. String val=serializer.deserialize(rowval);
  14. return Long.parseLong(val);
  15. } catch (Exception e) {
  16. return 0L;
  17. }
  18. }
  19. });
  20. }
文章来源: baocl.blog.csdn.net,作者:小黄鸡1992,版权归原作者所有,如需转载,请联系作者。
原文链接:baocl.blog.csdn.net/article/details/83684250
