oracle实战技巧(七)oracle时间戳与时间互相转换函数
小鲍侃java 发表于 2021/09/11 00:36:13 2021/09/11
【摘要】 时间戳转时间 CREATE OR REPLACEFUNCTION tamp_to_date (i_timestamp IN NUMBER ) return DATE IS r_date DATE;BEGINSELECT i_timestamp/(1000*60*60*24) + to_date('1970-01-01 08:00:00...
时间戳转时间
  1. CREATE OR REPLACE
  2. FUNCTION tamp_to_date (i_timestamp IN NUMBER ) return DATE IS r_date DATE;
  3. BEGIN
  4. SELECT
  5. i_timestamp/(1000*60*60*24) + to_date('1970-01-01 08:00:00','yyyy/mm/dd hh:mi:ss') into r_date from dual;
  6. return r_date;
  7. END tamp_to_date;
使用
  1. INSERT INTO earlywarning_programme (CREATE_TIME )
  2. VALUES
  3. (tamp_to_date (#{CREATETIME}))
时间转时间戳
  2. FUNCTION date_to_tamp (i_date IN DATE ) return NUMBER IS r_timestamp NUMBER;
  3. BEGIN
  4. SELECT
  5. ((i_date-to_date('1970-01-01','YYYY-MM-DD')) * 86400 - 8*3600)*1000 into r_timestamp from dual;
  6. return r_timestamp;
  7. END date_to_tamp;
使用
 date_to_tamp(create_time) as create_time,
文章来源: baocl.blog.csdn.net,作者:小黄鸡1992,版权归原作者所有,如需转载,请联系作者。
原文链接:baocl.blog.csdn.net/article/details/105660370
