Oracle SQL 语句:查看 redo log 每小时切换次数
Lucifer三思而后行 发表于 2021/09/10 22:01:59 2021/09/10
【摘要】 有时候,通过查看在线重做日志 redo log 每小时的切换次数,可以查看故障发生的时间点! SQL 语句如下: set linesize 260 pagesize 1000; col h0 for ...
SQL 语句如下:
col h0 for 999
col h1 for 999;
col h2 for 999;
col h3 for 999;
col h4 for 999;
col h5 for 999;
col h6 for 999;
col h7 for 999;
col h8 for 999;
col h9 for 999;
col h10 for 999;
col h11 for 999;
col h12 for 999;
col h13 for 999;
col h14 for 999;
col h15 for 999;
col h16 for 999;
col h17 for 999;
col h18 for 999;
col h19 for 999;
col h20 for 999
col h21 for 999;
col h22 for 999;
col h23 for 999;
SELECT TRUNC(first_time) "Date",
       TO_CHAR(first_time, 'Dy') "Day",
       COUNT(1) "Total",
       SUM(DECODE(TO_CHAR(first_time, 'hh24'), '00', 1, 0)) "h0",
       SUM(DECODE(TO_CHAR(first_time, 'hh24'), '01', 1, 0)) "h1",
       SUM(DECODE(TO_CHAR(first_time, 'hh24'), '02', 1, 0)) "h2",
       SUM(DECODE(TO_CHAR(first_time, 'hh24'), '03', 1, 0)) "h3",
       SUM(DECODE(TO_CHAR(first_time, 'hh24'), '04', 1, 0)) "h4",
       SUM(DECODE(TO_CHAR(first_time, 'hh24'), '05', 1, 0)) "h5",
       SUM(DECODE(TO_CHAR(first_time, 'hh24'), '06', 1, 0)) "h6",
       SUM(DECODE(TO_CHAR(first_time, 'hh24'), '07', 1, 0)) "h7",
       SUM(DECODE(TO_CHAR(first_time, 'hh24'), '08', 1, 0)) "h8",
       SUM(DECODE(TO_CHAR(first_time, 'hh24'), '09', 1, 0)) "h9",
       SUM(DECODE(TO_CHAR(first_time, 'hh24'), '10', 1, 0)) "h10",
       SUM(DECODE(TO_CHAR(first_time, 'hh24'), '11', 1, 0)) "h11",
       SUM(DECODE(TO_CHAR(first_time, 'hh24'), '12', 1, 0)) "h12",
       SUM(DECODE(TO_CHAR(first_time, 'hh24'), '13', 1, 0)) "h13",
       SUM(DECODE(TO_CHAR(first_time, 'hh24'), '14', 1, 0)) "h14",
       SUM(DECODE(TO_CHAR(first_time, 'hh24'), '15', 1, 0)) "h15",
       SUM(DECODE(TO_CHAR(first_time, 'hh24'), '16', 1, 0)) "h16",
       SUM(DECODE(TO_CHAR(first_time, 'hh24'), '17', 1, 0)) "h17",
       SUM(DECODE(TO_CHAR(first_time, 'hh24'), '18', 1, 0)) "h18",
       SUM(DECODE(TO_CHAR(first_time, 'hh24'), '19', 1, 0)) "h19",
       SUM(DECODE(TO_CHAR(first_time, 'hh24'), '20', 1, 0)) "h20",
       SUM(DECODE(TO_CHAR(first_time, 'hh24'), '21', 1, 0)) "h21",
       SUM(DECODE(TO_CHAR(first_time, 'hh24'), '22', 1, 0)) "h22",
       SUM(DECODE(TO_CHAR(first_time, 'hh24'), '23', 1, 0)) "h23",
       ROUND(COUNT(1) / 24, 2) "Avg"
  FROM v$log_history
 GROUP BY TRUNC(first_time), TO_CHAR(first_time, 'Dy')
 ORDER BY 1;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
本次分享到此结束啦~
如果觉得文章对你有帮助,点赞、收藏、关注、评论,一键四连支持,你的支持就是我创作最大的动力。
❤️ 技术交流可以 关注公众号:Lucifer三思而后行 ❤️
文章来源: luciferliu.blog.csdn.net,作者:Lucifer三思而后行,版权归原作者所有,如需转载,请联系作者。
原文链接:luciferliu.blog.csdn.net/article/details/120212358
