Oracle-Listener log解读
小工匠 发表于 2021/09/10 00:22:54 2021/09/10
【摘要】 Listener log 概述 在ORACLE数据库中,如果不对监听日志文件(listener.log)进行截断,那么监听日志文件(listener.log)会变得越来越大. Listener l...
Listener log 概述
Listener log location
For oracle 9i/10g
在下面的目录下:
 $ORACLE_HOME/network/log/listener_$ORACLE_SID.log
For oracle 11g/12c
在下面的目录下:
$ORACLE_BASE/diag/tnslsnr/主机名称/listener/trace/listener.log
这里写图片描述
或者通过 lsnrctl status 也可以查看位置
这里写图片描述
这里展示的是 xml格式的日志,跟.log并无区别。
或者11g可以通过 adrci 命令
oracle@entel2:[/oracle]$adrci
ADRCI: Release 11.2.0.4.0 - Production on Wed Nov 30 20:56:28 2016
Copyright (c) 1982, 2011, Oracle and/or its affiliates.  All rights reserved.
ADR base = "/oracle"
adrci> help  --help可以看帮助命令。输入help show alert,可以看到show alert的详细用法
 HELP [topic]
   Available Topics:
        CREATE REPORT
        ECHO
        EXIT
        HELP
        HOST
        IPS
        PURGE
        RUN
        SET BASE
        SET BROWSER
        SET CONTROL
        SET ECHO
        SET EDITOR
        SET HOMES | HOME | HOMEPATH
        SET TERMOUT
        SHOW ALERT
        SHOW BASE
        SHOW CONTROL
        SHOW HM_RUN
        SHOW HOMES | HOME | HOMEPATH
        SHOW INCDIR
        SHOW INCIDENT
        SHOW PROBLEM
        SHOW REPORT
        SHOW TRACEFILE
        SPOOL
 There are other commands intended to be used directly by Oracle, type
 "HELP EXTENDED" to see the list
adrci> show alert  --显示alert信息
Choose the alert log from the following homes to view:
1: diag/clients/user_oracle/host_880756540_80
2: diag/tnslsnr/procsdb2/listener_cc
3: diag/tnslsnr/entel2/sid_list_listener
4: diag/tnslsnr/entel2/listener_rb
5: diag/tnslsnr/entel2/listener
6: diag/tnslsnr/entel2/listener_cc
7: diag/tnslsnr/procsdb1/listener_rb
8: diag/rdbms/ccdg/ccdg
9: diag/rdbms/rb/rb
10: diag/rdbms/cc/cc
Q: to quit
Please select option: 5 --输入数字,查看对应日志
Output the results to file: /tmp/alert_13187_1397_listener_3.ado
2016-06-27 09:15:45.164000 -04:00
Create Relation ADR_CONTROL
Create Relation ADR_INVALIDATION
Create Relation INC_METER_IMPT_DEF
2016-06-27 09:15:46.444000 -04:00
Create Relation INC_METER_PK_IMPTS
System parameter file is /oracle/product/112/network/admin/listener.ora
Log messages written to /oracle/diag/tnslsnr/entel2/listener/alert/log.xml
Trace information written to /oracle/diag/tnslsnr/entel2/listener/trace/ora_16175_140656975550208.trc
Trace level is currently 0
Started with pid=16175
Listening on: (DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=10.45.7.198)(PORT=1521)))
Listening on: (DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=192.168.123.1)(PORT=1521)))
Listener completed notification to CRS on start
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
Listener log日志文件清理
需要对监听日志文件(listener.log)进行定期清理。
1:监听日志文件(listener.log)变得越来越大,占用额外的存储空间
2:监听日志文件(listener.log)变得太大会带来一些问题,查找起来也相当麻烦
3:监听日志文件(listener.log)变得太大,给写入、查看带来的一些性能问题、麻烦
定期对监听日志文件(listener.log)进行清理,另外一种说法叫截断日志文件。
列举一个错误的做法
oracle@entel2:[/oracle]$mv listener.log listener.log.20161201
oracle@entel2:[/oracle]$cp /dev/null listener.log
oracle@entel2:[/oracle]$more listener.log
如上所示,这样截断监听日志(listener.log)后,监听服务进程(tnslsnr)并不会将新的监听信息写入listener.log,而是继续写入listener.log.20161201
正确的做法
1:首先停止监听服务进程(tnslsnr)记录日志。
oracle@entel2:[/oracle]$lsnrctl  set log_status off
2:将监听日志文件(listener.log)复制一份,以listener.log.yyyymmdd格式命名
oracle@entel2:[/oracle]$cp listener.log listener.log.20161201
3:将监听日志文件(listener.log)清空。清空文件的方法有很多
oracle@entel2:[/oracle]$echo “” > listener.log
或者
或者
oracle@entel2:[/oracle]$echo /dev/null > listener.log
或者
oracle@entel2:[/oracle]$>listener.log
4:开启监听服务进程(tnslsnr)记录日志
oracle@entel2:[/oracle]$lsnrctl set log_status on
当然也可以移走监听日志文件(listener.log),数据库实例会自动创建一个listener.log文件。
oracle@entel2:[/oracle]$ lsnrctl set log_status off
oracle@entel2:[/oracle]$mv listener.log listener.yyyymmdd
清理shell脚本
当然这些操作应该通过shell脚本来处理,然后结合crontab作业定期清理、截断监听日志文件。
简单一点的(核心部分)
rq=` date +"%d" `
cp $ORACLE_HOME/network/log/listener.log $ORACLE_BACKUP/network/log/listener_$rq.log
su - oracle -c "lsnrctl set log_status off"
cp /dev/null $ORACLE_HOME/network/log/listener.log
su - oracle -c "lsnrctl set log_status on"
这样的脚本还没有解决一个问题,就是截断的监听日志文件保留多久的问题。比如我只想保留这些截断的监听日志一个月时间,我希望作业自动维护。不需要我去手工操作。有这样一个脚本cls_oracle.sh可以完全做到这个,当然它还会归档、清理其它日志文件,例如告警文件(alert_sid.log)等等。功能非常强大。
#!/bin/bash
# Script used to cleanup any Oracle environment.
# Cleans:      audit_log_dest
#              background_dump_dest
#              core_dump_dest
#              user_dump_dest
# Rotates:     Alert Logs
#              Listener Logs
# Scheduling:  00 00 * * * /home/oracle/_cron/cls_oracle/cls_oracle.sh -d 31 > /home/oracle/_cron/cls_oracle/cls_oracle.log 2>
&1
# Created By:  Tommy Wang  2012-09-10
# History:
RM="rm -f"
RMDIR="rm -rf"
LS="ls -l"
MV="mv"
TOUCH="touch"
TESTTOUCH="echo touch"
TESTMV="echo mv"
TESTRM=$LS
TESTRMDIR=$LS
SUCCESS=0
FAILURE=1
TEST=0
HOSTNAME=`hostname`
ORAENV="oraenv"
TODAY=`date +%Y%m%d`
ORIGPATH=/usr/local/bin:$PATH
ORIGLD=$LD_LIBRARY_PATH
export PATH=$ORIGPATH
# Usage function.
f_usage(){
  echo "Usage: `basename $0` -d DAYS [-a DAYS] [-b DAYS] [-c DAYS] [-n DAYS] [-r DAYS] [-u DAYS] [-t] [-h]"
  echo "       -d = Mandatory default number of days to keep log files that are not explicitly passed as parameters."
  echo "       -a = Optional number of days to keep audit logs."
  echo "       -b = Optional number of days to keep background dumps."
  echo "       -c = Optional number of days to keep core dumps."
  echo "       -n = Optional number of days to keep network log files."
  echo "       -r = Optional number of days to keep clusterware log files."
  echo "       -u = Optional number of days to keep user dumps."
  echo "       -h = Optional help mode."
  echo "       -t = Optional test mode. Does not delete any files."
if [ $# -lt 1 ]; then
  f_usage
  exit $FAILURE
fi
# Function used to check the validity of days.
f_checkdays(){
  if [ $1 -lt 1 ]; then
    echo "ERROR: Number of days is invalid."
    exit $FAILURE
  fi
  if [ $? -ne 0 ]; then
    exit $FAILURE
  fi
# Function used to cut log files.
f_cutlog(){
  # Set name of log file.
  LOG_FILE=$1
  CUT_FILE=${LOG_FILE}.${TODAY}
  FILESIZE=`ls -l $LOG_FILE | awk '{print $5}'`
  # Cut the log file if it has not been cut today.
  if [ -f $CUT_FILE ]; then
    echo "Log Already Cut Today: $CUT_FILE"
  elif [ ! -f $LOG_FILE ]; then
    echo "Log File Does Not Exist: $LOG_FILE"
  elif [ $FILESIZE -eq 0 ]; then
    echo "Log File Has Zero Size: $LOG_FILE"
  else
    # Cut file.
    echo "Cutting Log File: $LOG_FILE"
    $MV $LOG_FILE $CUT_FILE
    $TOUCH $LOG_FILE
  fi
# Function used to delete log files.
f_deletelog(){
  CLEAN_LOG=$1
  # Set time limit and confirm it is valid.
  CLEAN_DAYS=$2
  f_checkdays $CLEAN_DAYS
  # Delete old log files if they exist.
  find $CLEAN_LOG.[0-9][0-9][0-9][0-9][0-9][0-9][0-9][0-9] -type f -mtime +$CLEAN_DAYS -exec $RM {} \; 2>/dev/null
# Function used to get database parameter values.
f_getparameter(){
  if [ -z "$1" ]; then
    return
  fi
  PARAMETER=$1
  sqlplus -s /nolog <<EOF | awk -F= "/^a=/ {print \$2}"
set head off pagesize 0 feedback off linesize 200
whenever sqlerror exit 1
conn / as sysdba
select 'a='||value from v\$parameter where name = '$PARAMETER';
EOF
# Function to get unique list of directories.
f_getuniq(){
    return
  fi
  ARRCNT=0
  MATCH=N
  x=0
  for e in `echo $1`; do
    if [ ${#ARRAY[*]} -gt 0 ]; then
      # See if the array element is a duplicate.
      while [ $x -lt  ${#ARRAY[*]} ]; do
        if [ "$e" = "${ARRAY[$x]}" ]; then
          MATCH=Y
        fi
      done
    fi
    if [ "$MATCH" = "N" ]; then
      ARRAY[$ARRCNT]=$e
      ARRCNT=`expr $ARRCNT+1`
    fi
    x=`expr $x + 1`
  done
  echo ${ARRAY[*]}
# Parse the command line options.
while getopts a:b:c:d:n:r:u:th OPT; do
  case $OPT in
    a) ADAYS=$OPTARG
    b) BDAYS=$OPTARG
    c) CDAYS=$OPTARG
    d) DDAYS=$OPTARG
    n) NDAYS=$OPTARG
    r) RDAYS=$OPTARG
    u) UDAYS=$OPTARG
    t) TEST=1
    h) f_usage
       exit 0
    *) f_usage
       exit 2
  esac
done
shift $(($OPTIND - 1))
# Ensure the default number of days is passed.
if [ -z "$DDAYS" ]; then
  echo "ERROR: The default days parameter is mandatory."
  f_usage
  exit $FAILURE
fi
f_checkdays $DDAYS
echo "`basename $0` Started `date`."
# Use test mode if specified.
if [ $TEST -eq 1 ]
then
  RM=$TESTRM
  RMDIR=$TESTRMDIR
  MV=$TESTMV
  TOUCH=$TESTTOUCH
  echo "Running in TEST mode."
fi
# Set the number of days to the default if not explicitly set.
ADAYS=${ADAYS:-$DDAYS}; echo "Keeping audit logs for $ADAYS days."; f_checkdays $ADAYS
BDAYS=${BDAYS:-$DDAYS}; echo "Keeping background logs for $BDAYS days."; f_checkdays $BDAYS
CDAYS=${CDAYS:-$DDAYS}; echo "Keeping core dumps for $CDAYS days."; f_checkdays $CDAYS
NDAYS=${NDAYS:-$DDAYS}; echo "Keeping network logs for $NDAYS days."; f_checkdays $NDAYS
RDAYS=${RDAYS:-$DDAYS}; echo "Keeping clusterware logs for $RDAYS days."; f_checkdays $RDAYS
UDAYS=${UDAYS:-$DDAYS}; echo "Keeping user logs for $UDAYS days."; f_checkdays $UDAYS
# Check for the oratab file.
if [ -f /var/opt/oracle/oratab ]; then
  ORATAB=/var/opt/oracle/oratab
elif [ -f /etc/oratab ]; then
  ORATAB=/etc/oratab
else
  echo "ERROR: Could not find oratab file."
  exit $FAILURE
fi
# Build list of distinct Oracle Home directories.
OH=`egrep -i ":Y|:N" $ORATAB | grep -v "^#" | grep -v "\*" | cut -d":" -f2 | sort | uniq`
# Exit if there are not Oracle Home directories.
if [ -z "$OH" ]; then
  echo "No Oracle Home directories to clean."
  exit $SUCCESS
fi
# Get the list of running databases.
SIDS=`ps -e -o args | grep pmon | grep -v grep | awk -F_ '{print $3}' | sort`
# Gather information for each running database.
for ORACLE_SID in `echo $SIDS`
do
  # Set the Oracle environment.
  ORAENV_ASK=NO
  export ORACLE_SID
  . $ORAENV
    echo "Could not set Oracle environment for $ORACLE_SID."
  else
    export LD_LIBRARY_PATH=$ORACLE_HOME/lib:$ORIGLD
    ORAENV_ASK=YES
    echo "ORACLE_SID: $ORACLE_SID"
    # Get the audit_dump_dest.
    ADUMPDEST=`f_getparameter audit_dump_dest`
    if [ ! -z "$ADUMPDEST" ] && [ -d "$ADUMPDEST" 2>/dev/null ]; then
      echo "  Audit Dump Dest: $ADUMPDEST"
      ADUMPDIRS="$ADUMPDIRS $ADUMPDEST"
    fi
    # Get the background_dump_dest.
    BDUMPDEST=`f_getparameter background_dump_dest`
    echo "  Background Dump Dest: $BDUMPDEST"
    if [ ! -z "$BDUMPDEST" ] && [ -d "$BDUMPDEST" ]; then
      BDUMPDIRS="$BDUMPDIRS $BDUMPDEST"
    fi
    # Get the core_dump_dest.
    CDUMPDEST=`f_getparameter core_dump_dest`
    echo "  Core Dump Dest: $CDUMPDEST"
    if [ ! -z "$CDUMPDEST" ] && [ -d "$CDUMPDEST" ]; then
      CDUMPDIRS="$CDUMPDIRS $CDUMPDEST"
    fi
    # Get the user_dump_dest.
    UDUMPDEST=`f_getparameter user_dump_dest`
    echo "  User Dump Dest: $UDUMPDEST"
    if [ ! -z "$UDUMPDEST" ] && [ -d "$UDUMPDEST" ]; then
      UDUMPDIRS="$UDUMPDIRS $UDUMPDEST"
    fi
  fi
done
# Do cleanup for each Oracle Home.
for ORAHOME in `f_getuniq "$OH"`
do
  # Get the standard audit directory if present.
  if [ -d $ORAHOME/rdbms/audit ]; then
     ADUMPDIRS="$ADUMPDIRS $ORAHOME/rdbms/audit"
  fi
  # Get the Cluster Ready Services Daemon (crsd) log directory if present.
  if [ -d $ORAHOME/log/$HOSTNAME/crsd ]; then
    CRSLOGDIRS="$CRSLOGDIRS $ORAHOME/log/$HOSTNAME/crsd"
  fi
  # Get the  Oracle Cluster Registry (OCR) log directory if present.
  if [ -d $ORAHOME/log/$HOSTNAME/client ]; then
    OCRLOGDIRS="$OCRLOGDIRS $ORAHOME/log/$HOSTNAME/client"
  fi
  # Get the Cluster Synchronization Services (CSS) log directory if present.
  if [ -d $ORAHOME/log/$HOSTNAME/cssd ]; then
    CSSLOGDIRS="$CSSLOGDIRS $ORAHOME/log/$HOSTNAME/cssd"
  fi
  # Get the Event Manager (EVM) log directory if present.
  if [ -d $ORAHOME/log/$HOSTNAME/evmd ]; then
    EVMLOGDIRS="$EVMLOGDIRS $ORAHOME/log/$HOSTNAME/evmd"
  fi
  # Get the RACG log directory if present.
  if [ -d $ORAHOME/log/$HOSTNAME/racg ]; then
    RACGLOGDIRS="$RACGLOGDIRS $ORAHOME/log/$HOSTNAME/racg"
  fi
done
# Clean the audit_dump_dest directories.
if [ ! -z "$ADUMPDIRS" ]; then
  for DIR in `f_getuniq "$ADUMPDIRS"`; do
    if [ -d $DIR ]; then
      echo "Cleaning Audit Dump Directory: $DIR"
      find $DIR -type f -name "*.aud" -mtime +$ADAYS -exec $RM {} \; 2>/dev/null
    fi
  done
fi
# Clean the background_dump_dest directories.
if [ ! -z "$BDUMPDIRS" ]; then
  for DIR in `f_getuniq "$BDUMPDIRS"`; do
      echo "Cleaning Background Dump Destination Directory: $DIR"
      # Clean up old trace files.
      find $DIR -type f -name "*.tr[c,m]" -mtime +$BDAYS -exec $RM {} \; 2>/dev/null
      find $DIR -type d -name "cdmp*" -mtime +$BDAYS -exec $RMDIR {} \; 2>/dev/null
    fi
      # Cut the alert log and clean old ones.
      for f in `find $DIR -type f -name "alert\_*.log" ! -name "alert_[0-9A-Z]*.[0-9]*.log" 2>/dev/null`; do
        echo "Alert Log: $f"
        f_cutlog $f
        f_deletelog $f $BDAYS
      done
    fi
  done
fi
# Clean the core_dump_dest directories.
if [ ! -z "$CDUMPDIRS" ]; then
  for DIR in `f_getuniq "$CDUMPDIRS"`; do
      echo "Cleaning Core Dump Destination: $DIR"
      find $DIR -type d -name "core*" -mtime +$CDAYS -exec $RMDIR {} \; 2>/dev/null
    fi
  done
fi
# Clean the user_dump_dest directories.
if [ ! -z "$UDUMPDIRS" ]; then
  for DIR in `f_getuniq "$UDUMPDIRS"`; do
      echo "Cleaning User Dump Destination: $DIR"
      find $DIR -type f -name "*.trc" -mtime +$UDAYS -exec $RM {} \; 2>/dev/null
    fi
  done
fi
# Cluster Ready Services Daemon (crsd) Log Files
for DIR in `f_getuniq "$CRSLOGDIRS $OCRLOGDIRS $CSSLOGDIRS $EVMLOGDIRS $RACGLOGDIRS"`; do
    echo "Cleaning Clusterware Directory: $DIR"
    find $DIR -type f -name "*.log" -mtime +$RDAYS -exec $RM {} \; 2>/dev/null
  fi
done
# Clean Listener Log Files.
# Get the list of running listeners. It is assumed that if the listener is not running, the log file does not need to be cut.
ps -e -o args | grep tnslsnr | grep -v grep | while read LSNR; do
  # Derive the lsnrctl path from the tnslsnr process path.
  TNSLSNR=`echo $LSNR | awk '{print $1}'`
  ORACLE_PATH=`dirname $TNSLSNR`
  ORACLE_HOME=`dirname $ORACLE_PATH`
  PATH=$ORACLE_PATH:$ORIGPATH
  LSNRCTL=$ORACLE_PATH/lsnrctl
  echo "Listener Control Command: $LSNRCTL"
  # Derive the listener name from the running process.
  LSNRNAME=`echo $LSNR | awk '{print $2}' | tr "[:upper:]" "[:lower:]"`
  echo "Listener Name: $LSNRNAME"
  # Get the listener version.
  LSNRVER=`$LSNRCTL version | grep "LSNRCTL" | grep "Version" | awk '{print $5}' | awk -F. '{print $1}'`
  echo "Listener Version: $LSNRVER"
  # Get the TNS_ADMIN variable.
  echo "Initial TNS_ADMIN: $TNS_ADMIN"
  unset TNS_ADMIN
  TNS_ADMIN=`$LSNRCTL status $LSNRNAME | grep "Listener Parameter File" | awk '{print $4}'`
  if [ ! -z $TNS_ADMIN ]; then
    export TNS_ADMIN=`dirname $TNS_ADMIN`
  else
    export TNS_ADMIN=$ORACLE_HOME/network/admin
  fi
  echo "Network Admin Directory: $TNS_ADMIN"
  # If the listener is 11g, get the diagnostic dest, etc...
  if [ $LSNRVER -ge 11 ]; then
    # Get the listener log file directory.
    LSNRDIAG=`$LSNRCTL<<EOF | grep log_directory | awk '{print $6}'
set current_listener $LSNRNAME
show log_directory
EOF`
    echo "Listener Diagnostic Directory: $LSNRDIAG"
    # Get the listener trace file name.
    LSNRLOG=`lsnrctl<<EOF | grep trc_directory | awk '{print $6"/"$1".log"}'
show trc_directory
EOF`
    echo "Listener Log File: $LSNRLOG"
  # If 10g or lower, do not use diagnostic dest.
  else
    # Get the listener log file location.
    LSNRLOG=`$LSNRCTL status $LSNRNAME | grep "Listener Log File" | awk '{print $4}'`
  fi
  # See if the listener is logging.
  if [ -z "$LSNRLOG" ]; then
    echo "Listener Logging is OFF. Not rotating the listener log."
  # See if the listener log exists.
  elif  [ ! -r "$LSNRLOG" ]; then
    echo "Listener Log Does Not Exist: $LSNRLOG"
  # See if the listener log has been cut today.
  elif [ -f $LSNRLOG.$TODAY ]; then
    echo "Listener Log Already Cut Today: $LSNRLOG.$TODAY"
  # Cut the listener log if the previous two conditions were not met.
  else
    # Remove old 11g+ listener log XML files.
    if [ ! -z "$LSNRDIAG" ] && [ -d "$LSNRDIAG" ]; then
      echo "Cleaning Listener Diagnostic Dest: $LSNRDIAG"
      find $LSNRDIAG -type f -name "log\_[0-9]*.xml" -mtime +$NDAYS -exec $RM {} \; 2>/dev/null
    fi
    # Disable logging.
    $LSNRCTL <<EOF
set log_status off
EOF
    # Cut the listener log file.
    f_cutlog $LSNRLOG
    # Enable logging.
    $LSNRCTL <<EOF
set log_status on
EOF
    # Delete old listener logs.
    f_deletelog $LSNRLOG $NDAYS
  fi
done
echo "`basename $0` Finished `date`."
exit
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
  • 215
  • 216
  • 217
  • 218
  • 219
  • 220
  • 221
  • 222
  • 223
  • 224
  • 225
  • 226
  • 227
  • 228
  • 229
  • 230
  • 231
  • 232
  • 233
  • 234
  • 235
  • 236
  • 237
  • 238
  • 239
  • 240
  • 241
  • 242
  • 243
  • 244
  • 245
  • 246
  • 247
  • 248
  • 249
  • 250
  • 251
  • 252
  • 253
  • 254
  • 255
  • 256
  • 257
  • 258
  • 259
  • 260
  • 261
  • 262
  • 263
  • 264
  • 265
  • 266
  • 267
  • 268
  • 269
  • 270
  • 271
  • 272
  • 273
  • 274
  • 275
  • 276
  • 277
  • 278
  • 279
  • 280
  • 281
  • 282
  • 283
  • 284
  • 285
  • 286
  • 287
  • 288
  • 289
  • 290
  • 291
  • 292
  • 293
  • 294
  • 295
  • 296
  • 297
  • 298
  • 299
  • 300
  • 301
  • 302
  • 303
  • 304
  • 305
  • 306
  • 307
  • 308
  • 309
  • 310
  • 311
  • 312
  • 313
  • 314
  • 315
  • 316
  • 317
  • 318
  • 319
  • 320
  • 321
  • 322
  • 323
  • 324
  • 325
  • 326
  • 327
  • 328
  • 329
  • 330
  • 331
  • 332
  • 333
  • 334
  • 335
  • 336
  • 337
  • 338
  • 339
  • 340
  • 341
  • 342
  • 343
  • 344
  • 345
  • 346
  • 347
  • 348
  • 349
  • 350
  • 351
  • 352
  • 353
  • 354
  • 355
  • 356
  • 357
  • 358
  • 359
  • 360
  • 361
  • 362
  • 363
  • 364
  • 365
  • 366
  • 367
  • 368
  • 369
  • 370
  • 371
  • 372
  • 373
  • 374
  • 375
  • 376
  • 377
  • 378
  • 379
  • 380
  • 381
  • 382
  • 383
  • 384
  • 385
  • 386
  • 387
  • 388
  • 389
  • 390
  • 391
  • 392
  • 393
  • 394
  • 395
  • 396
  • 397
  • 398
  • 399
  • 400
  • 401
  • 402
  • 403
  • 404
  • 405
  • 406
  • 407
  • 408
  • 409
  • 410
  • 411
  • 412
  • 413
  • 414
  • 415
  • 416
  • 417
  • 418
  • 419
  • 420
  • 421
  • 422
  • 423
  • 424
  • 425
  • 426
  • 427
  • 428
  • 429
  • 430
  • 431
  • 432
  • 433
  • 434
  • 435
  • 436
  • 437
  • 438
  • 439
  • 440
  • 441
  • 442
  • 443
  • 444
  • 445
  • 446
  • 447
  • 448
  • 449
  • 450
  • 451
  • 452
  • 453
  • 454
  • 455
  • 456
  • 457
  • 458
  • 459
  • 460
  • 461
  • 462
  • 463
  • 464
  • 465
  • 466
  • 467
  • 468
  • 469
  • 470
  • 471
  • 472
  • 473
在crontab中设置一个作业,每天晚上凌晨零点运行这个脚本,日志文件保留31天。
00 00 * * * /home/oracle/_cron/cls_oracle/cls_oracle.sh -d 31 > /home/oracle/_cron/cls_oracle/cls_oracle.sh.log 2>&1
文章来源: artisan.blog.csdn.net,作者:小小工匠,版权归原作者所有,如需转载,请联系作者。
原文链接:artisan.blog.csdn.net/article/details/53416068
