五分钟带你玩转mybatis(二)常用标签
小鲍侃java 发表于 2021/09/09 23:52:50 2021/09/09
【摘要】 1.<select>  2.<insert> 3.<update> 4.<delete> 5.<foreach> <foreach collection="barcodeManageBo" item="object" separator="," o...
1.<select>
2.<insert>
3.<update>
4.<delete>
5.<foreach>
  1. <foreach collection="barcodeManageBo" item="object" separator=","
  2. open="(" close=")">
  3. #{object.id}
  4. </foreach>
open;以什么开始
close:以什么结束
separator:分隔符
collection:list名称
item:index名称
6.<sql>
  1. <sql id="sqlvalues">
  2. <if test="code!=null or code !=''">#{code},</if>
  3. <if test="itemname !=null or itemname !=''">#{itemname},</if>
  4. <if test="criteria !=null or criteria !=''">#{criteria},</if>
  5. </sql>
7.<include>>
<include refid="sqlvalues"></include>
引用sql标签
8.<set>
  1. <set>
  2. <if test="typeName != null and typeName != ''">
  3. typeName ={typeName},
  4. </if>
  5. <if test="sort != null and sort != ''">sort = #{sort},</if>
  6. </set>
在set时候省略最后一个符号
9.trim标签
  1. <trim suffix="" suffixOverrides=",">
  2. <if test="code!=null"> code = #{code},</if>
  3. <if test="itemname !=null"> itemname =#{itemname},</if>
  4. <if test="criteria !=null "> criteria =#{criteria},</if>
  5. </trim>
prefix:前缀覆盖并增加其内容
suffix:后缀覆盖并增加其内容
prefixOverrides:前缀判断的条件
suffixOverrides:后缀判断的条件
将,变成空格
10.<if>标签
11.<choose >
  1. <choose>
  2. <when test="title != null">
  3. and title = #{title}
  4. </when>
  5. <when test="content != null">
  6. and content = #{content}
  7. </when>
  8. <otherwise>
  9. and owner = "owner1"
  10. </otherwise>
  11. </choose>
12.<resultMap>
  1. <resultMap id="getStudentRM" type="EStudnet">
  2. <id property="id" column="ID"/>
  3. <result property="studentName" column="Name"/>
  4. <result property="studentAge" column="Age"/>
  5. </resultMap>
  6. <select id="getStudent" resultMap="getStudentRM">
  7. SELECT ID, Name, Age
  8. FROM TStudent
  9. </select>
其他sql小技巧
时间转为String
DATE_FORMAT(scanDate,'%Y-%m-%d %H:%i') as scanDate,
文章来源: baocl.blog.csdn.net,作者:小黄鸡1992,版权归原作者所有,如需转载,请联系作者。
原文链接:baocl.blog.csdn.net/article/details/83345691
