oracle实战技巧(四)oracle触发器(主键自增脚本)
小鲍侃java 发表于 2021/09/09 23:22:02 2021/09/09
【摘要】 create or replace trigger server_tri before insert on server for each row declare begin SELECT server_seq.Nextval INTO :NEW.id FROM DUAL; end server_tri; ...
  1. create or replace trigger server_tri
  2. before
  3. insert on server
  4. for each row
  5. declare
  6. begin
  7. SELECT server_seq.Nextval INTO :NEW.id FROM DUAL;
  8. end server_tri;
文章来源: baocl.blog.csdn.net,作者:小黄鸡1992,版权归原作者所有,如需转载,请联系作者。
原文链接:baocl.blog.csdn.net/article/details/105654078
