Java 8 - 时间API
小工匠 发表于 2021/09/09 23:33:17 2021/09/09
【摘要】 文章目录 Pre模拟SimpleDateFormate线程安全问题LocalDateLocalTimeLocalDateTimeInstantPeriodDurationformatparse ...
Pre
并发编程-12线程安全策略之常见的线程不安全类
package com.artisan.java8.testDate;
import java.text.ParseException;
import java.text.SimpleDateFormat;
import java.time.*;
import java.time.format.DateTimeFormatter;
import java.time.temporal.ChronoField;
import java.util.Date;
 * @author 小工匠
 * @version 1.0
 * @description: TODO
 * @date 2021/3/5 0:22
 * @mark: show me the code , change the world
public class DateInJava8 {
    public static void main(String[] args) throws ParseException, InterruptedException {
        Date date = new Date();
        System.out.println(date);
         *  模拟SimpleDateFormat 的线程安全问题
         *  Exception in thread "Thread-30" java.lang.NumberFormatException: multiple points
         *  Exception in thread "Thread-24" java.lang.NumberFormatException: For input string: "E.250214E4"
        SimpleDateFormat sdf = new SimpleDateFormat("YYYY-MM-dd");
        for (int i = 0; i < 100; i++) {
             new Thread(() -> {
                 for (int j = 0; j < 20; j++) {
                     try {
                         String format = sdf.format(date);
                         Date d = sdf.parse(format);
                         System.out.println(d);
                     } catch (ParseException e) {
                         e.printStackTrace();
             }).start();
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
LocalDate
https://nowjava.com/docs/java-api-11/java.base/java/time/LocalDate.html
LocalDate 是final修饰的不可变类 并且是线程安全的.
  • Java LocalDate is immutable class and hence thread safe.
  • LocalDate provides date output in the format of YYYY-MM-dd.
  • The LocalDate class has no time or Timezone data. So LocalDate is suitable to represent dates such as Birthday, National Holiday etc.
  • LocalDate class implements Temporal, TemporalAdjuster, ChronoLocalDate and Serializable interfaces.
  • LocalDate is a final class, so we can’t extend it.
  • LocalDate is a value based class, so we should use equals() method for comparing if two LocalDate instances are equal or not.
 public static void testLocalDate(){
        LocalDate x = LocalDate.now(); // 日期  2021-03-05
        System.out.println(x);
        LocalDate lo = LocalDate.of(2021,3,5);
        System.out.println(lo.getYear()); // 年  2021
        System.out.println(lo.getMonth()); // 月 MARCH
        System.out.println(lo.getDayOfMonth()); // 日 5
        System.out.println(lo.getDayOfYear()); // 一年中的第几天
        System.out.println(lo.getDayOfMonth());// 一个月中的第几天
        System.out.println(lo.getDayOfWeek());// 礼拜几
        System.out.println(lo.get(ChronoField.DAY_OF_MONTH));
LocalTime
  • LocalTime provides time without any time zone information. It is very much similar to observing the time from a wall clock which just shown the time and not the time zone information.
  • The assumption from this API is that all the calendar system uses the same way of representing the time.
  • It is a value-based class, so use of reference equality (==), identity hash code or synchronization on instances of LocalTime may have - unexpected results and is highly advised to be avoided. The equals method should be used for comparisons.
  • The LocalTime class is immutable that mean any operation on the object would result in a new instance of LocalTime reference.
private static void testLocalTime() {
        LocalTime time = LocalTime.now();
        System.out.println(time.getHour());
        System.out.println(time.getMinute());
        System.out.println(time.getSecond());
LocalDateTime
  • Java LocalDateTime is an immutable class, so it’s thread safe and suitable to use in multithreaded environment.
  • LocalDateTime provides date and time output in the format of YYYY-MM-DD-hh-mm-ss.zzz, extendable to nanosecond precision. So we can store “2017-11-10 21:30:45.123456789” in LocalDateTime object.
  • Just like the LocalDate class, LocalDateTime has no time zone data. We can use LocalDateTime instance for general purpose date and time information.
  • LocalDateTime class implements Comparable, ChronoLocalDateTime, Temporal, TemporalAdjuster, TermporalAccessor and Serializable interfaces.
  • LocalDateTime is a final class, so we can’t extend it.
  • LocalDateTime is a value based class, so we should use equals() method to check if two instances of LocalDateTime are equal or not.
  • LocalDateTime class is a synergistic ‘combination’ of LocalDate and LocalTime with the contatenated format as shown in the figure above.
    private static void testLocalDateTime() {
        LocalDate localDate = LocalDate.now();
        LocalDateTime localDateTime = LocalDateTime.of(localDate, time);
        System.out.println(localDateTime.toString());
        LocalDateTime now = LocalDateTime.now();
        System.out.println(now);
Instant
    private static void testInstant() throws InterruptedException {
        Instant start = Instant.now();
        Thread.sleep(1000L);
        Instant end = Instant.now();
        Duration duration = Duration.between(start, end);
        System.out.println(duration.toMillis());
Period
    private static void testPeriod() {
        Period period = Period.between(LocalDate.of(2020, 5, 10),LocalDate.of(2021, 3, 4));
        System.out.println(period.getYears());
        System.out.println(period.getMonths());
        System.out.println(period.getDays());
Duration
   private static void testDuration() {
        System.out.println(time);
        LocalTime beforeTime = time.minusHours(2);
        System.out.println(beforeTime);
        Duration duration = Duration.between(beforeTime,time );
        System.out.println(duration.toHours());
format
    private static void testDateFormat() {
        String format1 = localDate.format(DateTimeFormatter.BASIC_ISO_DATE);
        System.out.println(format1);
        DateTimeFormatter mySelfFormatter = DateTimeFormatter.ofPattern("yyyy-MM-dd");
        String format = localDate.format(mySelfFormatter);
        System.out.println(format);
parse
  private static void testDateParse() {
        String date1 = "20210305";
        LocalDate localDate = LocalDate.parse(date1, DateTimeFormatter.BASIC_ISO_DATE);
        System.out.println(localDate);
        String date2 = "2021-03-05";
        LocalDate localDate2 = LocalDate.parse(date2, mySelfFormatter);
        System.out.println(localDate2);
文章来源: artisan.blog.csdn.net,作者:小小工匠,版权归原作者所有,如需转载,请联系作者。
原文链接:artisan.blog.csdn.net/article/details/114394036
