python 轨迹识别
风吹稻花香 发表于 2021/09/08 22:42:40 2021/09/08
【摘要】 判断曲率 https://zhuanlan.zhihu.com/p/72083902 import numpy as npimport numpy.linalg as LAfrom matplotlib import pyplot as plt def PJcurvature(x ,y): """ input ...
判断曲率
  1. import numpy as np
  2. import numpy.linalg as LA
  3. from matplotlib import pyplot as plt
  4. def PJcurvature(x ,y):
  5. """
  6. input : the coordinate of the three point
  7. output : the curvature and norm direction
  8. refer to https://github.com/Pjer-zhang/PJCurvature for detail
  9. """
  10. t_a = LA.norm([x[1 ] -x[0] ,y[1 ] -y[0]])
  11. t_b = LA.norm([x[2 ] -x[1] ,y[2 ] -y[1]])
  12. M = np.array([
  13. [1, -t_a, t_a**2],
  14. [1, 0, 0 ],
  15. [1, t_b, t_b**2]
  16. ])
  17. a = np.matmul(LA.inv(M) ,x)
  18. b = np.matmul(LA.inv(M) ,y)
  19. kappa = 2* (a[2] * b[1] - b[2] * a[1]) / (a[1] ** 2. + b[1] ** 2.) ** (1.5)
  20. return kappa, [b[1], -a[1]] / np.sqrt(a[1] ** 2. + b[1] ** 2.)
  21. if __name__ == '__main__':
  22. theta_arr = np.linspace(0, np.pi *
文章来源: blog.csdn.net,作者:AI视觉网奇,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/jacke121/article/details/120169879
