asm与数据库实例内存参数建议
snowofsummer 发表于 2021/09/08 09:00:06 2021/09/08
【摘要】 当数据库没有使用自动内存管理,需求修改SGA内存参数,适当支持ASM。当使用了自动内存管理则不需要设置。PROCESSES initialization parameter—Add 16 to the current valueLARGE_POOL_SIZE initialization parameter—Add an additional 600K to the current valu...
当使用了自动内存管理则不需要设置。
  • PROCESSES initialization parameter—Add 16 to the current value
  • LARGE_POOL_SIZE initialization parameter—Add an additional 600K to the current value
  • SHARED_POOL_SIZE 根据数据库大小调
    For disk groups using external redundancy, every 100 GB of space needs 1 MB of extra shared pool plus 2 MB
    For disk groups using normal redundancy, every 50 GB of space needs 1 MB of extra shared pool plus 4 MB
    For disk groups using high redundancy, every 33 GB of space needs 1 MB of extra shared pool plus 6 MB
  • 数据库大小计算公式
SELECT SUM(bytes)/(1024*1024*1024) FROM V$DATAFILE;
SELECT SUM(bytes)/(1024*1024*1024) FROM V$LOGFILE a, V$LOG b
       WHERE a.group#=b.group#;
SELECT SUM(bytes)/(1024*1024*1024) FROM V$TEMPFILE
       WHERE status='ONLINE';
