152_Java_SpringSSMBuild
alexsully 发表于 2021/08/30 19:19:28 2021/08/30
【摘要】 SSM整合案例
1 Maven项目pom依赖
2 基本结构和配置框架
    com.alex.pojo
    com.alex.dao
    com.alex.service
    com.alex.controller
@Data
@AllArgsConstructor
@NoArgsConstructor
@Repository
public class Books {
    private int bookID;
    private String bookName;
    private int bookCounts;
    private String detail;
public interface BookMapper {
    //增加一本书
    int addBook(Books books);
    //删除一本书
    int deleteBookById(@Param("bookId") int id);
    //更新一本书
    int updateBook(Books books);
    //查询一本书
    Books queryBookById(@Param("bookId") int id);
    //查询全部的书
    List<Books> queryAllBook();
public interface BookService {
    //增加一本书
    //删除一本书
    //更新一本书
    //查询一本书
    //查询全部的书
BookServiceImpl
package com.alex.service;
import com.alex.dao.BookMapper;
import com.alex.pojo.Books;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.stereotype.Service;
import java.util.List;
 * @author Alexsully
 * @create 2021-08-30 12:04
@Service
public class BookServiceImpl implements BookService{
    //service调dao层: 组合Dao
    @Autowired
    private BookMapper bookMapper;
    public void setBookMapper(BookMapper bookMapper) {
        this.bookMapper = bookMapper;
    @Override
    public int addBook(Books books) {
        return bookMapper.addBook(books);
    @Override
    public int deleteBookById(int id) {
        return bookMapper.deleteBookById(id);
    @Override
    public int updateBook(Books books) {
        return bookMapper.updateBook(books);
    @Override
    public Books queryBookById(int id) {
        return bookMapper.queryBookById(id);
    @Override
    public List<Books> queryAllBook() {
        return bookMapper.queryAllBook();
3 Mybatis层编写
    1 数据库配置文件database.properties
    2 IDEA关联数据库
    3 编写MyBatis的核心配置文件 mybatis-config.xml
    4 编写数据库对应的实体类 com.alex.pojo.Books 使用lombok插件!
    5 编写Dao层的Mapper接口!
    6 编写接口对应的 Mapper.xml 文件,需要导入MyBatis的包;
    7 编写Service层的接口和实现类
database.properties
jdbc.Driver=com.mysql.jdbc.Driver
#如果使用8.0 增加一个时区配置; &serverTimezone=Asia/Shanghai
jdbc.url=jdbc:mysql://127.0.0.1:3306/ssmbuild?useUnicode=true&characterEncoding=utf8&serverTimezone=Asia/Shanghai
jdbc.username=root
jdbc.password=xxxx
mybatis-config.xml
<?xml version="1.0" encoding="UTF-8" ?>
<!DOCTYPE configuration
        PUBLIC "-//mybatis.org//DTD Config 3.0//EN"
        "http://mybatis.org/dtd/mybatis-3-config.dtd">
<configuration>
    <!--配置数据源,交给Spring去做-->
    <typeAliases>
        <package name="com.alex.pojo"/>
    </typeAliases>
    <mappers>
        <mapper resource="com/alex/dao/BookMapper.xml"/>
    </mappers>
</configuration>
Mapper.xml
<!DOCTYPE mapper
        "http://mybatis.org/dtd/mybatis-3-mapper.dtd">
<mapper namespace="com.alex.dao.BookMapper">
    <insert id="addBook" parameterType="Books">
        insert into ssmbuild.books (bookName, bookCounts, detail)
        values (#{bookName},#{bookCounts},#{detail});
    </insert>
    <delete id="deleteBookById" parameterType="int">
        delete from ssmbuild.books
        where bookID = #{bookId}
    </delete>
    <update id="updateBook" parameterType="Books">
        update ssmbuild.books
        set bookName=#{bookName},bookCounts=#{bookCounts},detail=#{detail}
        where bookID=#{bookID} ;
    </update>
    <select id="queryBookById" resultType="Books">
        select * from ssmbuild.books
    </select>
    <select id="queryAllBook" resultType="Books">
    </select>
</mapper>
4 Spring层
    1 配置Spring整合MyBatis,使用c3p0连接池;
    2 Spring整合Mybatis的相关的配置文件: spring-dao.xml
    3 Spring整合service层  spring-service.xml
spring-dao.xml
<beans xmlns="http://www.springframework.org/schema/beans"
       xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
       xmlns:context="http://www.springframework.org/schema/context"
       xsi:schemaLocation="http://www.springframework.org/schema/beans
       http://www.springframework.org/schema/beans/spring-beans.xsd
       https://www.springframework.org/schema/context/spring-context.xsd">
    <!--1.关联数据库配置文件-->
    <context:property-placeholder location="classpath:database.properties"/>
    <!--2.连接池
      dbcp: 半自动化操作 , 不能自动连接
      c3p0: 自动化操作(自动化的加载配置文件,并且可以自动设置到对象中!)
      druid : hikari
    <bean id="dataSource" class="com.mchange.v2.c3p0.ComboPooledDataSource">
        <!--数据库的基本配置-->
        <property name="driverClass" value="${jdbc.Driver}"/>
        <property name="jdbcUrl" value="${jdbc.url}"/>
        <property name="user" value="${jdbc.username}"/>
        <property name="password" value="${jdbc.password}"/>
        <!-- c3p0连接池的私有属性 -->
        <property name="maxPoolSize" value="30"/>
        <property name="minPoolSize" value="10"/>
        <!-- 关闭连接后不自动commit -->
        <property name="autoCommitOnClose" value="false"/>
        <!-- 获取连接超时时间 -->
        <property name="checkoutTimeout" value="10000"/>
        <!-- 当获取连接失败重试次数 -->
        <property name="acquireRetryAttempts" value="2"/>
    </bean>
    <!--3.sqlSessionFactory-->
    <bean id="sqlSessionFactory" class="org.mybatis.spring.SqlSessionFactoryBean">
        <property name="dataSource" ref="dataSource"/>
        <!--绑定Mybatis的配置文件-->
        <property name="configLocation" value="classpath:mybatis-config.xml"/>
    </bean>
    <!--4.注册dao层bean-->
    <!--反射动态实现dao接口注入Spring容器中-->
    <bean class="org.mybatis.spring.mapper.MapperScannerConfigurer">
        <!--注入 sqlSessionFactory -->
        <property name="sqlSessionFactoryBeanName" value="sqlSessionFactory"/>
        <!--要扫描的dao包-->
        <property name="basePackage" value="com.alex.dao"/>
    </bean>
</beans>
spring-service.xml
       xmlns:tx="http://www.springframework.org/schema/tx" xmlns:aop="http://www.springframework.org/schema/aop"
        http://www.springframework.org/schema/tx/spring-tx.xsd http://www.springframework.org/schema/aop https://www.springframework.org/schema/aop/spring-aop.xsd">
    <!--1.扫描service下的包-->
    <context:component-scan base-package="com.alex.service"/>
    <!--2.将我们的所有业务类,注入到Spring,可以通过配置,或者注解实现-->
    <bean id="bookServiceImpl" class="com.alex.service.BookServiceImpl">
        <property name="bookMapper" ref="bookMapper"/>
    </bean>
    <!--3.声明式事务配置-->
    <bean id="transactionManager" class="org.springframework.jdbc.datasource.DataSourceTransactionManager">
        <!--注入数据源-->
    </bean>
    <!--4.aop事务支持!-->
    <!-- 结合AOP实现事务的织入 配置事务通知-->
    <tx:advice id="txAdvice" transaction-manager="transactionManager">
        <!--给那些方法配置事务-->
        <!--配置事务的传播特性:new propagation= -->
        <tx:attributes>
            <tx:method name="*" propagation="REQUIRED"/>
        </tx:attributes>
    </tx:advice>
    <!--3 配置事务切入-->
    <!-- execution()表达式的主体 第一个*符号 表示返回值的类型任意 -->
    <!--aop 切面 aspect 就是个类, advice通知-类中方法,pointcut 切入点-->
    <!--切入点  expression:表达式匹配要执行的方法-->
    <!--执行环绕; advice-ref执行方法  pointcut-ref切入点-->
    <aop:config>
        <aop:pointcut id="txPointCut" expression="execution(* com.alex.dao.*.*(..))" />
        <aop:advisor advice-ref="txAdvice" pointcut-ref="txPointCut"/>
    </aop:config>
</beans>
5 SpringMVC层
    1 web.xml    2 spring-mvc.xml
   3 Spring配置整合文件,applicationContext.xml
controller
package com.alex.controller;
import com.alex.service.BookService;
import org.springframework.beans.factory.annotation.Qualifier;
import org.springframework.stereotype.Controller;
import org.springframework.ui.Model;
import org.springframework.web.bind.annotation.PathVariable;
import org.springframework.web.bind.annotation.RequestMapping;
 * @author Alexsully
 * @create 2021-08-30 13:36
@Controller
@RequestMapping("/book")
public class BookController {
    @Autowired
    @Qualifier("bookServiceImpl")
    private BookService bookService;
    //展示全部的书籍
    @RequestMapping("/allBook")
    public String list(Model model){
        List<Books> list = bookService.queryAllBook();
        model.addAttribute("list",list);
        return "allBook";
    //跳转到新增书籍页面
    @RequestMapping("/toAddBook")
    public String toAddBook(){
        return "addBook";
    //增加书籍页面
    @RequestMapping("/addBook")
    public String addBook(Books books){
        bookService.addBook(books);
        return "redirect:/book/allBook"; //重定向到首页
    //跳转到修改页面
    @RequestMapping("/toUpdateBook")
    public String toUpdateBook(int id,Model model){
        Books books = bookService.queryBookById(id);
        model.addAttribute("book",books);
        return "redirect:updateBook";
    //修改书籍
    @RequestMapping("/updateBook")
    public String updateBook(Books books,Model model){
        System.out.println("调试信息updateBook===="+books);
        bookService.updateBook(books);
        //更新最新的书籍
        Books books1 = bookService.queryBookById(books.getBookID());
        model.addAttribute("books",books1);
        System.out.println("修改后的书籍===="+books1);
    //删除书籍,请使用restful风格
//    带占位符的 URL 是 Spring3.0 新增的功能,该功能在SpringMVC 向 REST 目标挺进发展过程中具有里程碑的意义。
//    通过 @PathVariable 可以将 URL 中占位符参数绑定到控制器处理方法的入参中:URL 中的 {xxx} 占位符可以通过
//    @PathVariable("xxx") 绑定到操作方法的入参中
    @RequestMapping("/del/{bookID}")
    public String deleteBook(@PathVariable("bookID") int id){
        bookService.deleteBookById(id);
 1 web.xml
<web-app xmlns="http://xmlns.jcp.org/xml/ns/javaee"
         xsi:schemaLocation="http://xmlns.jcp.org/xml/ns/javaee http://xmlns.jcp.org/xml/ns/javaee/web-app_4_0.xsd"
         version="4.0">
    <!--DispatchServlet-->
    <servlet>
        <servlet-name>springmvc</servlet-name>
        <servlet-class>org.springframework.web.servlet.DispatcherServlet</servlet-class>
        <init-param>
            <param-name>contextConfigLocation</param-name>
            <param-value>classpath:applicationContext.xml</param-value>
        </init-param>
        <load-on-startup>1</load-on-startup>
    </servlet>
    <servlet-mapping>
        <url-pattern>/</url-pattern>
    </servlet-mapping>
    <!--乱码过滤-->
    <filter>
        <filter-name>encodingFilter</filter-name>
        <filter-class>org.springframework.web.filter.CharacterEncodingFilter</filter-class>
        <init-param>
            <param-name>encoding</param-name>
            <param-value>utf-8</param-value>
        </init-param>
    </filter>
    <filter-mapping>
        <url-pattern>/*</url-pattern>
    </filter-mapping>
    <!--Session-->
    <session-config>
        <session-timeout>15</session-timeout>
    </session-config>
</web-app>
2 spring-mvc.xml
       xmlns:mvc="http://www.springframework.org/schema/mvc"
       http://www.springframework.org/schema/mvc/spring-mvc.xsd
    <!--1.注解驱动-->
    <mvc:annotation-driven/>
    <!--2.静态资源过滤-->
    <mvc:default-servlet-handler/>
    <!--3.扫描包:controller-->
    <context:component-scan base-package="com.alex.controller"/>
    <!--4.视图解析器-->
    <bean class="org.springframework.web.servlet.view.InternalResourceViewResolver">
        <property name="prefix" value="/WEB-INF/jsp/"/>
        <property name="suffix" value=".jsp"/>
    </bean>
</beans>
       http://www.springframework.org/schema/beans/spring-beans.xsd">
    <import resource="classpath:spring-dao.xml"/>
    <import resource="classpath:spring-service.xml"/>
    <import resource="classpath:spring-mvc.xml"/>
</beans>
pom.xml
<project xmlns="http://maven.apache.org/POM/4.0.0"
         xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
    <modelVersion>4.0.0</modelVersion>
    <groupId>com.alex</groupId>
    <artifactId>ssmbuild</artifactId>
    <version>1.0-SNAPSHOT</version>
    <!--依赖: junit,数据库驱动,连接池,servlet,jsp,mybatis,mybattis-spring,spring,-->
    <dependencies>
        <!--Junit-->
        <dependency>
            <groupId>junit</groupId>
            <artifactId>junit</artifactId>
            <version>4.12</version>
        </dependency>
        <!--数据库驱动-->
        <dependency>
            <groupId>mysql</groupId>
            <artifactId>mysql-connector-java</artifactId>
            <version>5.1.47</version>
        </dependency>
        <!-- 数据库连接池: c3p0:dbcp-->
        <dependency>
            <groupId>com.mchange</groupId>
            <artifactId>c3p0</artifactId>
            <version>0.9.5.2</version>
        </dependency>
        <!--Servlet - JSP -->
        <dependency>
            <groupId>javax.servlet</groupId>
            <artifactId>servlet-api</artifactId>
            <version>2.5</version>
        </dependency>
        <dependency>
            <groupId>javax.servlet.jsp</groupId>
            <artifactId>jsp-api</artifactId>
            <version>2.2</version>
        </dependency>
        <dependency>
            <artifactId>jstl</artifactId>
            <version>1.2</version>
        </dependency>
        <!--Mybatis-->
        <dependency>
            <groupId>org.mybatis</groupId>
            <artifactId>mybatis</artifactId>
            <version>3.5.2</version>
        </dependency>
        <dependency>
            <artifactId>mybatis-spring</artifactId>
            <version>2.0.2</version>
        </dependency>
        <!--Spring-->
        <dependency>
            <groupId>org.springframework</groupId>
            <artifactId>spring-webmvc</artifactId>
            <version>5.1.9.RELEASE</version>
        </dependency>
        <dependency>
            <artifactId>spring-jdbc</artifactId>
        </dependency>
        <dependency>
            <groupId>org.aspectj</groupId>
            <artifactId>aspectjweaver</artifactId>
            <version>1.8.13</version>
        </dependency>
        <!--Lombok-->
        <dependency>
            <groupId>org.projectlombok</groupId>
            <artifactId>lombok</artifactId>
            <version>1.16.10</version>
        </dependency>
    </dependencies>
    <!--静态资源导出问题-->
    <build>
        <resources>
            <resource>
                <directory>src/main/java</directory>
                <includes>
                    <include>**/*.properties</include>
                    <include>**/*.xml</include>
                </includes>
                <filtering>false</filtering>
            </resource>
            <resource>
                <directory>src/main/resources</directory>
                <includes>
                </includes>
            </resource>
        </resources>
    </build>
</project>
