phpunit: This test did not perform any assertions
彭世瑜 发表于 2021/08/27 23:56:27 2021/08/27
【摘要】 phpunit 没有使用断言语句测试不通过, This test did not perform any assertions 1 如果仅仅想执行单个函数,不想加断言,可以使用注解 <?php...
<?php
declare(strict_types=1);
use PHPUnit\Framework\TestCase;
class TokenServiceTest extends TestCase
     * @doesNotPerformAssertions
    public function testGetToken(){
        echo 'hello';
参考
PHPUnit passing a test with no assertions within config
原文链接:pengshiyu.blog.csdn.net/article/details/119927196
