Unity 之 解决2019之后的版本打apk卡到Building Gradle project问题
陈言必行 发表于 2021/08/25 22:22:04 2021/08/25
【摘要】 Unity 之 解决2019之后的版本打apk卡到Building Gradle project问题
一,遇到问题
安装环境:安装Android Build Support;【需要将下拉菜单的两项一并安装】
222
问题:
Unity2019 版本打包apk,卡到Building Gradle project这一直不动,长时间等待后打包失败
111
二,分析问题
失败原因:是在下载的对应版本Gradle时,需要访问外网下载速度慢或者网络不稳定导致失败
三,解决问题
方法一:修改配置文件
1,找到Untiy安装目录下的AndroidPlayer\Tools\GradleTemplates文件夹下的 baseProjectTemplate.gradle 文件
参考我的目录:
D:\Program Files\Unity\2019.4.19f1c1\Editor\Data\PlaybackEngines\AndroidPlayer\Tools\GradleTemplates
444
// GENERATED BY UNITY. REMOVE THIS COMMENT TO PREVENT OVERWRITING WHEN EXPORTING AGAIN
allprojects {
    buildscript {
        repositories {**ARTIFACTORYREPOSITORY**
            google()
            jcenter()
        dependencies {
            // If you are changing the Android Gradle Plugin version, make sure it is compatible with the Gradle version preinstalled with Unity
            // See which Gradle version is preinstalled with Unity here https://docs.unity3d.com/Manual/android-gradle-overview.html
            // See official Gradle and Android Gradle Plugin compatibility table here https://developer.android.com/studio/releases/gradle-plugin#updating-gradle
            // To specify a custom Gradle version in Unity, go do "Preferences > External Tools", uncheck "Gradle Installed with Unity (recommended)" and specify a path to a custom Gradle version
            classpath 'com.android.tools.build:gradle:3.4.0'
            **BUILD_SCRIPT_DEPS**
        google()
        jcenter()
        flatDir {
            dirs "${project(':unityLibrary').projectDir}/libs"
task clean(type: Delete) {
    delete rootProject.buildDir
修改为:
allprojects {
    buildscript {
            //google()
            //jcenter()
           maven{ url 'http://maven.aliyun.com/repository/google'}
           maven{ url 'http://maven.aliyun.com/repository/gradle-plugin'}
           maven{ url 'http://maven.aliyun.com/nexus/content/groups/public/'}
           maven{ url 'http://maven.aliyun.com/repository/jcenter'}
        dependencies {
        //google()
        //jcenter()
        flatDir {
然后重新打包即可。
方法二:修改Preferences属性
在官网上提前下载好需要版本gradle:https://gradle.org/releases/
然后在Preferences面板上,将Gradle Installed…选项前面√取消勾选,然后点击“Browse”,找到自己下载好的gradle,然后重新打包就可以了。
333
