Mybatis学习笔记(三)动态SQL标签详解
Code皮皮虾 发表于 2021/08/25 21:55:16 2021/08/25
【摘要】 Mybatis学习笔记(三)动态SQL标签详解
1、基本环境搭建
建立数据库
建表语句
CREATE TABLE `t_teacher` (
  `id` int(11) NOT NULL AUTO_INCREMENT,
  `teacherName` varchar(100) DEFAULT NULL,
  `class_name` varchar(100) DEFAULT NULL,
  `address` varchar(100) DEFAULT NULL,
  `birth_date` date DEFAULT NULL,
  PRIMARY KEY (`id`)
) ENGINE=InnoDB AUTO_INCREMENT=4 DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_0900_ai_ci;
创建对应实体类
public class Teacher {
	private Integer id;
	private String name;
	private String course;
	private String address;
	private Date brith;
	//省略get、set、toString方法
Dao
public interface TeacherDao {
	public Teacher getTeacherById(Integer id);
xml
<?xml version="1.0" encoding="UTF-8" ?>
<!DOCTYPE mapper
 PUBLIC "-//mybatis.org//DTD Mapper 3.0//EN"
 "http://mybatis.org/dtd/mybatis-3-mapper.dtd">
<!-- namespace:名称空间;写接口的全类名,相当于告诉Mybatis这个配置文件是实现哪个接口的 -->
<mapper namespace="com.dong.dao.TeacherDao">
	<select id="getTeacherById" resultMap="teacherMap">
		select * from t_teacher where id = #{id}
	</select>
	<resultMap type="com.dong.bean.Teacher" id="teacherMap">
		<id column="id" property="id"/>
		<result column="address" property="address"/>
		<result column="teacherName" property="name"/>
		<result column="birth_date" property="brith"/>
		<result column="class_name" property="course"/>
	</resultMap>
</mapper>
项目整体结构
测试
@Test
public void test() throws IOException {
	String resource = "mybatis-config.xml";
	InputStream inputStream = Resources.getResourceAsStream(resource);
	SqlSessionFactory sqlSessionFactory = new SqlSessionFactoryBuilder().build(inputStream);
	Teacher empById;
	//获取和数据库的一次会话:getConnection()
	SqlSession openSession = sqlSessionFactory.openSession();
	try {
		//使用SqlSession操作数据库,获取dao接口的实现
		TeacherDao mapper = openSession.getMapper(TeacherDao.class);
		empById = mapper.getTeacherById(1);
		System.out.println(empById);
	} finally {
		//关闭连接
		openSession.close();
查询成功
2、动态SQL——if标签
dao
xml
</resultMap>
<!--if:判断-->
<select id="getTeacherByCondition" resultMap="teacherMap">
	<!--test="":编写条件
		id!=null:取出javaBean属性中的id的值,判断是否为空
	<if test="id!=null">
		id > #{id} and
	</if>
	<if test="name!=null &amp;&amp; !name.equals(&quot;&quot;)">
		teacherName like #{name} and
	</if>
	<if test="brith!=null">
		birth_date > #{brith}
	</if>
</select>
测试
@Test
	try {
		Teacher teacher = new Teacher();
		teacher.setId(1);
		teacher.setName("%a%");
		teacher.setBrith(new Date());
		List<Teacher> teacherByCondition = mapper.getTeacherByCondition(teacher);
		System.out.println(teacherByCondition);
	} finally {
		//关闭连接
在XML写判断条件很容易出现写的字符需要转义
W3cSchool转义对照表
3、动态SQL——Where标签
在使用mybatis的动态sql时,有时候遇到根据条件判断添加where后面的筛选条件,会出现多余的“and”或者“or。
使用Where标签
注意去掉t_teacher本来后面的where
可以看到数据查出来了
where 元素只会在至少有一个子元素的条件返回 SQL 子句的情况下才去插入“WHERE”子句。而且,若语句的开头为“AND”或“OR”,where 元素也会将它们去除。
4、动态SQL——trim标签
		prefix="":前缀,为我们下面的sql整体添加一个前缀
		prefixOverrides="":取出整体字符串前面多余的字符
		suffix="":为整体添加一个后缀
		suffixOverrides="":后面哪个多了可以去掉
	<trim prefix="where" suffixOverrides="and">
		id > #{id} and
		</if>
		</if>
			birth_date > #{brith} and
		</if>
	</trim>
</select>
测试
5、动态SQL——foreach标签
dao
xml
<select id="getTeacherByIdIn" resultMap="teacherMap">
	select * from t_teacher where id in
		index="":索引
			如果遍历的是一个list:
				index:指定的变量保存了当前索引
				item:保存当前便利的元素的值
			如果遍历的是一个map:
				index:指定的变量就是保存了当前遍历的元素的key
				item:就是保存当前遍历的元素的值
		collection="" :指定遍历集合的key
		item="" : 每次遍历出的元素起一个变量名方便引用
		open="" :以什么开始
		close="" : 以什么结束
		separator="" : 每次遍历的元素的分隔符
	<foreach collection="ids" open="(" close=")" item="id_item" separator=",">
	</foreach>
</select>
测试
6、动态SQL——choose分支选择
有时候,我们不想使用所有的条件,而只是想从多个条件中选择一个使用。针对这种情况,MyBatis 提供了 choose 元素,它有点像 Java 中的 switch 语句。
dao
xml
<select id="getTeacherByConditionChoose" resultMap="teacherMap">
	<where>
		<choose>
			<when test="id!=null">
				id=#{id}
			</when>
			<when test="name!=null">
			</when>
			<when test="brith!=null">
				brith_data = #{brith}
			</when>
			<!-- 其他 -->
			<otherwise>
				<!-- 查所有 -->
				1=1
			</otherwise>
		</choose>
	</where>
</select>
测试
可以看见只按照了**id查询
7、动态SQL——使用if结合set完成mybatis动态更新
dao
xml
测试
虽然条件拼上了,但是逗号还在,这时我们可以使用set标签替换语句中的set
成功更新
s
觉得博主写的不错的读者大大们,可以点赞关注和收藏哦,谢谢各位!
process=image/format,png#pic_center)
