【Python自动化办公入门教学】Excel篇:xlsxwriter 、openpyxl写入Excel
Code皮皮虾 发表于 2021/08/25 21:35:17 2021/08/25
【摘要】 【Python自动化办公入门教学】Excel篇:xlsxwriter 、openpyxl写入Excel
1、安装库
打开cmd命令行输入命令pip install xlsxwriter 和 pip install openpyxl即可安装
xlsxwriter文档
openpyxl中文文档
2、xlsxwriter写入Excel
import xlsxwriter as xw
#指定excel路径,没有就创建
work = xw.Workbook("G:/PyCharmProjects/PythonAutomation/excel/newtest01.xlsx")
#新建工作表
sheet = work.add_worksheet("one")
for i in range(0,301):
    sheet.write(0,i,i)
#关闭
work.close()
3、openpyxl写入Excel
import openpyxl
work = openpyxl.load_workbook("G:/PyCharmProjects/PythonAutomation/excel/newtest01.xlsx")
sheet = work['one']
sheet['A2'] = "A2"
sheet['A3'] = "A3"
sheet['A4'] = "A4"
sheet['A5'] = "A5"
work.save("G:/PyCharmProjects/PythonAutomation/excel/newtest01.xlsx")
4、写入有格式的excel表
新建有样式的excel表
使用xlsxwriter写入
work = xw.Workbook("G:/PyCharmProjects/PythonAutomation/excel/geshi.xlsx")
sheet = work.add_worksheet("Sheet1")
for i in range(1,5):
	#指定第i行,第3列写入(索引从0开始)
    sheet.write(i,3,i)
work.close()
原有数据丢失
使用openpyxl写入
import openpyxl
work = openpyxl.load_workbook("G:/PyCharmProjects/PythonAutomation/excel/geshi.xlsx")
#指定工作表
sheet = work['Sheet1']
#写入
sheet['A2'] = "A2"
sheet['A3'] = "A3"
sheet['A4'] = "A4"
sheet['A5'] = "A5"
work.save("G:/PyCharmProjects/PythonAutomation/excel/geshi.xlsx")
可见,样式没有问题
博主会持续更新,有兴趣的小伙伴可以==点赞==、==关注==和==收藏==下哦,你们的支持就是我创作最大的动力!
