android开发之broadcast学习笔记
江南一点雨 发表于 2021/08/16 23:38:42 2021/08/16
【摘要】 android中的广播用的太多了,今天稍微总结一下。 按注册方式分为两种: 1.静态注册广播: 静态注册广播就是在androidManifest.xml文件中注册广播,假设我们要实现这样一个效果,在一个activity上点击按钮,发送一条广播,这条广播弹出一个toast,显示“静态”二字。 先看看广播接受者: public class MyBroadc...
按注册方式分为两种:
1.静态注册广播:
先看看广播接受者:
public class MyBroadcast extends BroadcastReceiver { @Override public void onReceive(Context context, Intent intent) { Toast.makeText(context,"静态", Toast.LENGTH_LONG).show(); }
清单文件中注册:
 <receiver android:name="com.example.staticbroadcast.MyBroadcast" > <intent-filter> <action android:name="com.test.StaticBroadcast" /> </intent-filter> </receiver>
activity中的点击事件(发送广播):
 this.static_btn.setOnClickListener(new OnClickListener() { @Override public void onClick(View v) { Intent intent = new Intent(); intent.setAction("com.test.StaticBroadcast"); sendBroadcast(intent); } });
2.动态注册。
动态注册一般是在activity中的onStart()方法中注册,在onStop()方法中解除注册,代码如下:
public class MainActivity extends Activity { private Button static_btn; private Button dynamic_btn; private BroadcastReceiver myBroadcastReceiver; @Override protected void onCreate(Bundle savedInstanceState) { super.onCreate(savedInstanceState); setContentView(R.layout.activity_main); this.static_btn = (Button) this.findViewById(R.id.button1); this.dynamic_btn = (Button) this.findViewById(R.id.Button01); myBroadcastReceiver = new BroadcastReceiver(){ @Override public void onReceive(Context context, Intent intent) { Toast.makeText(MainActivity.this,"你好,这里是动态广播!", Toast.LENGTH_LONG).show(); } };
// this.static_btn.setOnClickListener(new OnClickListener() {
// @Override
// public void onClick(View v) {
// Intent intent = new Intent();
// intent.setAction("com.test.StaticBroadcast");
// sendBroadcast(intent);
// }); this.dynamic_btn.setOnClickListener(new OnClickListener() { @Override public void onClick(View v) { //发送广播 Intent intent = new Intent(); intent.setAction("DynamicBroadcast"); sendBroadcast(intent); } }); } @Override protected void onStart() { super.onStart(); //注册广播 IntentFilter intentFilter = new IntentFilter(); intentFilter.addAction("DynamicBroadcast"); registerReceiver(myBroadcastReceiver, intentFilter); } @Override protected void onStop() { super.onStop(); //取消注册 unregisterReceiver(myBroadcastReceiver); }
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
关于静态注册的细节:
android:exported=”true”这个属性表示该广播接收器是否接收来自其他App发出的广播,如果有intent-filter属性,则默认为true,否则默认为false。
每个广播接收者都可以接受多个广播源,如果是静态注册,那么你要这么做:
 <receiver android:exported="true" android:name="com.example.staticbroadcast.MyBroadcast" > <intent-filter> <action android:name="com.test.StaticBroadcast" /> <action android:name="com.test.StaticBroadcast2"/> </intent-filter> </receiver>
在广播接收器中这样处理:
 @Override public void onReceive(Context context, Intent intent) { if (intent.getAction().equals("com.test.StaticBroadcast")) { Toast.makeText(context, "静态", Toast.LENGTH_SHORT).show(); } else if (intent.getAction().equals("com.test.StaticBroadcast2")) { Toast.makeText(context, "静态2", Toast.LENGTH_SHORT).show(); } }
如果是动态注册,注册方式如下:
 @Override protected void onStart() { super.onStart(); //注册广播 IntentFilter intentFilter = new IntentFilter(); intentFilter.addAction("DynamicBroadcast"); intentFilter.addAction("DynamicBroadcast2"); registerReceiver(myBroadcastReceiver, intentFilter); }
广播接收器中的处理方式与静态注册一致。
关于怎样使用broadcast实现activity和fragment之间的通信可以查看我的另一篇博客使用Broadcast实现android组件之间的通信
本文参考了:http://www.cnblogs.com/lwbqqyumidi/p/4168017.html
文章来源: wangsong.blog.csdn.net,作者:_江南一点雨,版权归原作者所有,如需转载,请联系作者。
原文链接:wangsong.blog.csdn.net/article/details/46955787
