C#编程-13:ProgressBar制作时间进度倒计时_彭世瑜_新浪博客
彭世瑜 发表于 2021/08/14 23:50:39 2021/08/14
【摘要】 源码: using System; using System.Collections.Generic; using System.ComponentModel; using System.Data; using System.Drawing; using System.Linq; ...
源码:
using System;
using System.Data;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
namespace WindowsFormsProgressBar
    public partial class Form1 : Form
        private void outLog(string str)
            txtOut.AppendText(DateTime.Now.ToString() + str + "\n");
        public Form1()
            InitializeComponent();
        private void Form1_Load(object sender, EventArgs e)
            btnBegin.Enabled = false;
            btnStop.Enabled = false;
            btnFinish.Enabled = false;
        private void btnSetup_Click(object sender, EventArgs e)
            try
                if (txtInput.Text.Trim() != "")
                    progressBar1.Minimum = 0;
                    progressBar1.Maximum = Convert.ToInt32(txtInput.Text);
                    progressBar1.Step = -1;
                    progressBar1.Value = progressBar1.Maximum;
                    btnSetup.Enabled = false;
                    btnBegin.Enabled = true;
                    outLog("时间设置正确,请按开始键继续。。。");
            catch {
                MessageBox.Show("请输入一个正确的秒数!");
        private void btnBegin_Click(object sender, EventArgs e)
            btnStop.Enabled = true;
            btnFinish.Enabled = true;
            timer1.Start();
        private void timer1_Tick(object sender, EventArgs e)
            if (progressBar1.Value > progressBar1.Minimum)
                progressBar1.PerformStep();
                string per = Convert.ToDouble(progressBar1.Value) / Convert.ToDouble(progressBar1.Maximum) * 100 + "%";
                if (per != "0%")
                    outLog("进度条正在工作,剩余:" + per);
                //else
                //    outLog("进度条已完成");
                //    btnSetup.Enabled = true;
            else
                outLog("进度完成!");
                timer1.Stop();
        private void btnStop_Click(object sender, EventArgs e)
            if (timer1.Enabled == true)
                outLog("stop");
                btnStop.Text = "继续";
                timer1.Stop();
            else {
                outLog("继续工作");
                btnStop.Text = "暂停";
                timer1.Start();
        private void btnFinish_Click(object sender, EventArgs e)
            outLog("停止工作\n==================");
            timer1.Enabled = false;
            progressBar1.Value = 0;
练习笔记:
1、 Convert.ToInt32(txtInput.Text),类型强制转换,字符串型数据转为整型数据。
2、progressBar1.PerformStep(),进度条执行一次步进。   Perform v.执行
原文链接:pengshiyu.blog.csdn.net/article/details/109661708
