Python编程:tornado实现WebSocket通讯
彭世瑜 发表于 2021/08/14 00:39:26 2021/08/14
【摘要】 以下实例有点像广播通讯,支持多个客户端连接 代码参考别人的,稍微做了一点点修改 服务器端 websocket_demo.py # -*- coding: utf-8 -*- from __future__ import unicode_literals, print_function from datetime import datetime import os...
代码参考别人的,稍微做了一点点修改
import os
import tornado
from tornado.options import define, options
from tornado.web import RequestHandler
from tornado.websocket import WebSocketHandler
# 设置服务器端口
define("port", default=2222, type=int)
class IndexHandler(RequestHandler): def get(self): self.render("chat-client.html")
class ChatHandler(WebSocketHandler): users = set()  # 用来存放在线用户的容器 def open(self): # 建立连接后添加用户到容器中 self.users.add(self) # 向已在线用户发送消息 for user in self.users: remote_ip, port = self.request.connection.context.address now = datetime.now().strftime("%H:%M:%S") user.write_message("[{}][{}:{}]-进入聊天室".format(now, remote_ip, port)) def on_message(self, message): # 向在线用户广播消息 now = datetime.now().strftime("%H:%M:%S") remote_ip, port = self.request.connection.context.address for user in self.users: user.write_message("[{}][{}:{}] {}".format(now, remote_ip, port, message)) def on_close(self): # 用户关闭连接后从容器中移除用户 now = datetime.now().strftime("%H:%M:%S") remote_ip, port = self.request.connection.context.address self.users.remove(self) for user in self.users: user.write_message("[{}][{}:{}]-离开聊天室".format(now, remote_ip, port)) def check_origin(self, origin): return True  # 允许WebSocket的跨域请求
if __name__ == '__main__': tornado.options.parse_command_line() app = tornado.web.Application([ (r"/", IndexHandler), (r"/chat", ChatHandler), ], static_path=os.path.join(os.path.dirname(__file__), "static"), template_path=os.path.join(os.path.dirname(__file__), "template"), debug=True ) http_server = tornado.httpserver.HTTPServer(app) http_server.listen(options.port) tornado.ioloop.IOLoop.current().start()
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
客户端 template/chat-client.html
<!DOCTYPE html>
<html>
<head> <meta charset="utf-8"> <title>聊天室</title>
</head>
<body> <div id="contents" style="height:500px;overflow:auto;"></div> <div> <textarea id="msg"></textarea> <a href="javascript:;" onclick="sendMsg()">发送</a> </div>
<!-- jQuery -->
<script src="https://cdn.staticfile.org/jquery/3.3.1/jquery.min.js"></script>
<script type="text/javascript"> var ws = new WebSocket("ws://127.0.0.1:2222/chat"); ws.onmessage = function(e) { $("#contents").append("<p>" + e.data + "</p>"); }; function sendMsg() { var msg = $("#msg").val(); ws.send(msg); $("#msg").val(""); }
</script>
</body>
</html>
  • 26
  • 27
  • 28
  • 29
  • 30
通讯效果,打开两个网页
参考 :
Python Tornado之WebSocket聊天室
原文链接:pengshiyu.blog.csdn.net/article/details/90047794
