TypeError: Object of type 'datetime' is not JSON serializable
彭世瑜 发表于 2021/08/13 23:34:33 2021/08/13
【摘要】 json序列化时间对象的时候报错: TypeError: Object of type 'datetime' is not JSON serializable 1 解决办法 重写json序列化类 # -*- coding: utf-8 -*- import json import datetime class DateEncoder(json.JSON...
json序列化时间对象的时候报错:
解决办法
重写json序列化类
import json
import datetime
class DateEncoder(json.JSONEncoder): def default(self, obj): if isinstance(obj, datetime.datetime): return obj.strftime('%Y-%m-%d %H:%M:%S') elif isinstance(obj, datetime.date): return obj.strftime("%Y-%m-%d") else: return json.JSONEncoder.default(self, obj)
if __name__ == '__main__': data = {"name": "Tom", "birthday": datetime.datetime.now()} print(json.dumps(data, cls=DateEncoder)) # {"name": "Tom", "birthday": "2019-06-06 17:24:19"}
参考:
python datetime.datetime is not JSON serializable 报错问题解决
原文链接:pengshiyu.blog.csdn.net/article/details/91047387
