VB编程:利用控件数组设置控件状态-38
彭世瑜 发表于 2021/08/14 02:01:11 2021/08/14
【摘要】 运行效果: 程序代码: Private Sub Form_Load()     For i = 0 To Label1.Count - 1         Label1(i).Caption = "移动鼠标"   &n...
运行效果:
程序代码:
    Next i
End Sub
Private Sub Label1_MouseMove(Index As Integer, Button As Integer, Shift As Integer, X As Single, Y As Single)
    Dim mouseover As Boolean
    mouseover = (0 <= X) And (X <= Label1(Index).Width)
    If mouseover Then
            Label1(i).ForeColor = &H0&
        Next i
        Label1(Index).ForeColor = &HFF&
    End If
End Sub
学习总结:
    1、Count 返回 Long(长整数),包含集合中的对象数目。
原文链接:pengshiyu.blog.csdn.net/article/details/81048887
