C#编程:用Substring获取文件路径文件名扩展名-2_彭世瑜_新浪博客
彭世瑜 发表于 2021/08/14 01:47:37 2021/08/14
【摘要】 private void button1_Click(object sender, EventArgs e)         {             if (openFileDialog1.ShowDialog() ==...
            if (openFileDialog1.ShowDialog() == DialogResult.OK)
                textBox1.Text = openFileDialog1.FileName;
                string strAll = openFileDialog1.FileName;
                string strPath =
                    strAll.Substring(0, strAll.LastIndexOf("\\") + 1);
                string strFileName=
                    strAll.Substring(strAll.LastIndexOf("\\")+1,
                    strAll.LastIndexOf(".")-
                    (strAll.LastIndexOf("\\")+1));
                string strFileext =
                    strAll.Substring(strAll.LastIndexOf(".") + 1,
                    strAll.Length-strAll.LastIndexOf(".")-1
                label1.Text = "文件路径: " + strPath;
                label2.Text = "文件名称: " + strFileName;
                label3.Text = "扩展名: " + strFileext;
小结:
IndexOf()和LastIndexOf() 如果没找到匹配字符返回-1;
原文链接:pengshiyu.blog.csdn.net/article/details/109661647
