C#编程-22:判断文件是否存在并创建文件(夹)
彭世瑜 发表于 2021/08/14 00:32:02 2021/08/14
【摘要】 string path = @"D:\abc"; string fileName = "123.txt"; if (!Directory.Exists(path)) {     Directory.CreateDirectory(path); } ...
if (!File.Exists(path + "\\" + fileName))
    File.Create(path + "\\" + fileName);
原文链接:pengshiyu.blog.csdn.net/article/details/81048950
