C#编程-29:循环访问目录树
彭世瑜 发表于 2021/08/14 00:54:13 2021/08/14
【摘要】 using System; using System.Collections.Generic; using System.Linq; using System.Text; using System.IO; namespace FileClass {     class Progra...
using System;
using System.Linq;
using System.Text;
using System.IO;
namespace FileClass
    class Program
        static System.Collections.Specialized.StringCollection log = new System.Collections.Specialized.StringCollection();
        static void Main(string[] args)
            //获取逻辑分区
            string[] drives = System.Environment.GetLogicalDrives();
            foreach (string d in drives)
                System.IO.DriveInfo di=new System.IO.DriveInfo(d);
                //排除
                if (!di.IsReady)
                    Console.WriteLine("drive is not ready:{0}",di);
                    continue;
                    Console.WriteLine("drive is ready:{0}", di);
                    DirectoryInfo dirRoot = di.RootDirectory;
                    WalkDirectoryTree(dirRoot);
            Console.WriteLine("exception:");
            foreach (string s in log)
                Console.WriteLine(s);
                StreamWriter writer = new StreamWriter(@"C:\Users\PSY\Desktop\list.txt", true, Encoding.Default);
                writer.WriteLine(s);
                writer.Close();
            Console.ReadKey();
        /// 遍历文件夹
        public static void WalkDirectoryTree(System.IO.DirectoryInfo root)
            System.IO.FileInfo[] files = null;
            System.IO.DirectoryInfo[] subDirs = null;
            try
                files = root.GetFiles("*.*");
            catch (UnauthorizedAccessException e)
                log.Add(e.Message);
            catch(DirectoryNotFoundException e)
                Console.WriteLine(e.Message);
            if (files != null)
                foreach (FileInfo fi in files)
                    Console.WriteLine(fi.FullName);
                    StreamWriter writer = new StreamWriter(@"C:\Users\PSY\Desktop\list.txt",true,Encoding.Default);
                    writer.WriteLine(fi.FullName);
                    writer.Close();
                //递归调用
                subDirs = root.GetDirectories();
                foreach (DirectoryInfo dirInfo in subDirs)
                    WalkDirectoryTree(dirInfo);
关键笔记:
1、获取本机逻辑分区:
2、获取所有文件:(DirectoryInfo dir)
FileInfo[] fileInfo = dir.GetFiles();
3、获取所有目录:(DirectoryInfo dir)
 DirectoryInfo[] directoryInfo = dir.GetDirectories();
参考链接:https://docs.microsoft.com/zh-cn/dotnet/csharp/programming-guide/file-system/how-to-iterate-through-a-directory-tree
原文链接:pengshiyu.blog.csdn.net/article/details/81048982
