C#编程-27:复制文件和目录_彭世瑜_新浪博客
彭世瑜 发表于 2021/08/14 01:11:37 2021/08/14
【摘要】             ///拷贝单个文件             string fileName = "test.txt";             str...
            ///拷贝单个文件
            string sourcePath = @"D:\source";
            string targetPath = @"D:\target";
            string sourceFile = Path.Combine(sourcePath,fileName);
            string destFile = Path.Combine(targetPath,fileName);
            if (!Directory.Exists(targetPath))
                Directory.CreateDirectory(targetPath);
            File.Copy(sourceFile,destFile,true);
            ///拷贝多个文件
            if (Directory.Exists(sourcePath))
                string[] files = Directory.GetFiles(sourcePath);
                foreach (string s in files)
                    fileName = Path.GetFileName(s);
                    destFile = Path.Combine(targetPath, fileName);
                    File.Copy(s, destFile, true);
            else {
                Console.WriteLine("source path dose not exist! ");
            Console.WriteLine("press any key to exit.");
            Console.ReadKey();
原文链接:pengshiyu.blog.csdn.net/article/details/109661725
