C#编程-31:获取驱动器信息
彭世瑜 发表于 2021/08/14 01:52:30 2021/08/14
【摘要】 1、新建驱动器信息对象: DriveInfo di = new DriveInfo(@"c:\"); string[] drives = System.Environment.GetLogicalDrives();   2、获取根目录信息: DirectoryInfo dirInfo = di.RootDirectory...
1、新建驱动器信息对象:
2、获取根目录信息:
DirectoryInfo dirInfo = di.RootDirectory;
3、获取所有文件:
FileInfo[] fileNames = dirInfo.GetFiles("*.*");
string[] files = Directory.GetFiles(currentDirName,"*.*");
4、获取所有文件夹:
DirectoryInfo[] dirInfos = dirInfo.GetDirectories("*.*");
5、获取应用程序当前路径:
string currentDirName = Directory.GetCurrentDirectory();
6、设置当前路径:
Directory.SetCurrentDirectory(path);
参考链接:
https://docs.microsoft.com/zh-cn/dotnet/csharp/programming-guide/file-system/how-to-get-information-about-files-folders-and-drives
原文链接:pengshiyu.blog.csdn.net/article/details/81048981
