C#编程-35:写入读取文本文件
彭世瑜 发表于 2021/08/14 00:48:19 2021/08/14
【摘要】 using System.IO; 1、写入文本 File.WriteAllLines(@"d:\test.txt",lines); File.WriteAllText(@"d:\text.txt",text);  using (StreamWriter writer =...
using System.IO;
1、写入文本
 using (StreamWriter writer = new StreamWriter(@"d:\text.txt",true))
                foreach (string line in lines)
                    if (!line.Contains("second"))
                        writer.WriteLine(line);
2、读取文件
string s = File.ReadAllText(@"d:\text.txt");
string[] ls = File.ReadAllLines(@"d:\text.txt");
int counter = 0;
            string current;
            StreamReader reader = new StreamReader(@"d:\text.txt");
            while((current=reader.ReadLine())!=null){
                Console.WriteLine(current);
                counter++;
            reader.Close();
原文链接:pengshiyu.blog.csdn.net/article/details/81049027
