C#编程-69:DataReader和DataSet读取数据库内容示例_彭世瑜_新浪博客
彭世瑜 发表于 2021/08/14 01:01:22 2021/08/14
【摘要】 源码如下: using System; using System.Collections.Generic; using System.Linq; using System.Text; using System.Data; using System.D...
源码如下:
  1. using System;
  2. using System.Collections.Generic;
  3. using System.Linq;
  4. using System.Text;
  5. using System.Data;
  6. using System.Data.SqlClient;
  7.
  8. namespace SQLLastTest
  9. {
  10.     class Program
  11.     {
  12.         static void Main(string[] args)
  13.         {
  14.             //连接字符串
  15.             SqlConnectionStringBuilder sqlsb = new SqlConnectionStringBuilder();
  16.             sqlsb.DataSource = @"(localdb)\Projects";
  17.             sqlsb.IntegratedSecurity = true;
  18.             sqlsb.InitialCatalog = "company";
  19.
  20.             //连接数据库,采用try...catch形式
  21.             SqlConnection sqlcon = new SqlConnection(sqlsb.ToString());
  22.             try
  23.             {
  24.
  25.                 sqlcon.Open();
  26.                 string sql = "select * from clerk";
  27.                 SqlCommand sqlcom = new SqlCommand(sql,sqlcon);
  28.
  29.                 //使用SqlDataReader打印表信息
  30.                 SqlDataReader sqlread = sqlcom.ExecuteReader();
  31.                 Console.WriteLine("使用SqlDataReader打印表信息:");
  32.                 for (int i = 0; i < sqlread.FieldCount; i++)
  33.                 {
  34.                     Console.Write(sqlread.GetName(i)+"\t");
  35.                 }
  36.                 Console.WriteLine();
  37.                 while (sqlread.Read())
  38.                 {
  39.                     for (int i = 0; i < sqlread.FieldCount; i++)
  40.                     {
  41.                         Console.Write(sqlread[i].ToString()+"\t");
  42.                     }
  43.                     Console.WriteLine();
  44.                 }
  45.                 sqlread.Close();
  46.
  47.                 //使用DataSet打印表信息
  48.                 Console.WriteLine("使用DataSet打印表信息:");
  49.                 SqlDataAdapter sqladp = new SqlDataAdapter(sql,sqlcon);
  50.                 DataSet dataSet = new DataSet();
  51.                 sqladp.Fill(dataSet,"clerk");
  52.                 foreach (DataTable table in dataSet.Tables)
  53.                 {
  54.                     foreach (DataColumn col in table.Columns)
  55.                     {
  56.                         Console.Write(col.ColumnName+"\t");
  57.                     }
  58.                     Console.WriteLine();
  59.                     foreach (DataRow row in table.Rows)
  60.                     {
  61.                         foreach (DataColumn col in table.Columns)
  62.                         {
  63.                             Console.Write(row[col]+"\t");
  64.                         }
  65.                         Console.WriteLine();
  66.                     }
  67.                 }
  68.
  69.             }
  70.             catch(Exception ex)
  71.             {
  72.                 Console.WriteLine(ex.Message);
  73.             }
  74.             finally
  75.             {
  76.                 sqlcon.Close();
  77.             }
  78.             Console.ReadKey();
  79.         }
  80.     }
  81. }
原文链接:pengshiyu.blog.csdn.net/article/details/109661792
