C#编程-72:dataGridView删除行_彭世瑜_新浪博客
彭世瑜 发表于 2021/08/14 01:40:21 2021/08/14
【摘要】 using System; using System.Windows.Forms;   namespace DataGridViewContextMenuStrip {     public partial class Form1 :&nbsp...
  1. using System;
  2. using System.Windows.Forms;
  3.
  4. namespace DataGridViewContextMenuStrip
  5. {
  6.     public partial class Form1 : Form
  7.     {
  8.         public Form1()
  9.         {
  10.             InitializeComponent();
  11.         }
  12.
  13.         private void Form1_Load(object sender, EventArgs e)
  14.         {
  15.             // TODO:  这行代码将数据加载到表“companyDataSet.clerk”中。您可以根据需要移动或删除它。
  16.             this.clerkTableAdapter.Fill(this.companyDataSet.clerk);
  17.
  18.         }
  19.         private int rowIndex;
  20.         private void dataGridView1_CellMouseUp(object sender, DataGridViewCellMouseEventArgs e)
  21.         {
  22.             if (e.Button == MouseButtons.Right)
  23.             {
  24.                 rowIndex=e.RowIndex;
  25.                 this.dataGridView1.Rows[e.RowIndex].Selected = true;
  26.
  27.                 this.dataGridView1.CurrentCell = dataGridView1.Rows[e.RowIndex].Cells[1];
  28.                 this.contextMenuStrip1.Show(dataGridView1, e.Location);
  29.                 this.contextMenuStrip1.Show(Cursor.Position);
  30.             }
  31.         }
  32.
  33.         private void 删除ToolStripMenuItem_Click(object sender, EventArgs e)
  34.         {
  35.             if (!this.dataGridView1.Rows[rowIndex].IsNewRow)
  36.             {
  37.                 this.dataGridView1.Rows.RemoveAt(rowIndex);
  38.             }
  39.         }
  40.     }
  41. }
原文链接:pengshiyu.blog.csdn.net/article/details/109661794
