C#编程-71:dataGridView获取行列坐标索引和值_彭世瑜_新浪博客
彭世瑜 发表于 2021/08/13 23:44:33 2021/08/13
【摘要】    private void dataGridView1_CellClick(object sender, DataGridViewCellEventArgs e)         {  &nbsp...
  1.    private void dataGridView1_CellClick(object sender, DataGridViewCellEventArgs e)
  2.         {
  3.             //获取行列坐标索引
  4.             //方法一:
  5.             //int row = e.RowIndex+1;
  6.             //int col = e.ColumnIndex+1;
  7.
  8.             //方法二:
  9.             //int row = dataGridView1.CurrentCell.RowIndex + 1;
  10.             //int col = dataGridView1.CurrentCell.ColumnIndex + 1;
  11.
  12.             //方法三:
  13.             //int row = dataGridView1.CurrentCellAddress.Y + 1;
  14.             int col=dataGridView1.CurrentCellAddress.X+1;
  15.
  16.             //方法四:
  17.             int row = dataGridView1.CurrentRow.Index + 1;
  18.
  19.             //获取当前单元格内容
  20.             //方法1:
  21.
  22.            // string cell = dataGridView1.Rows[row-1].Cells[col-1].Value.ToString();
  23.
  24.             //方式2:
  25.             string cell = dataGridView1.CurrentCell.Value.ToString();
  26.
  27.             MessageBox.Show("点击:"+row+"行;"+col+"列\n内容是:"+cell);
  28.         }
原文链接:pengshiyu.blog.csdn.net/article/details/109661801
