C#编程-80:DataGridView单元格自动填充_彭世瑜_新浪博客
彭世瑜 发表于 2021/08/14 00:30:51 2021/08/14
【摘要】 using System; using System.Collections.Generic; using System.ComponentModel; using System.Data; using System.Drawing; using System.Linq; usin...
  1. using System;
  2. using System.Collections.Generic;
  3. using System.ComponentModel;
  4. using System.Data;
  5. using System.Drawing;
  6. using System.Linq;
  7. using System.Text;
  8. using System.Windows.Forms;
  9.
  10. namespace DataGridViewAutoFill
  11. {
  12.     public partial class Form1 : Form
  13.     {
  14.         public Form1()
  15.         {
  16.             InitializeComponent();
  17.         }
  18.
  19.         private void Form1_Load(object sender, EventArgs e)
  20.         {
  21.             // TODO:  这行代码将数据加载到表“companyDataSet.clerk”中。您可以根据需要移动或删除它。
  22.             this.clerkTableAdapter.Fill(this.companyDataSet.clerk);
  23.
  24.         }
  25.
  26.         private void dataGridView1_EditingControlShowing(object sender, DataGridViewEditingControlShowingEventArgs e)
  27.         {
  28.             string title = dataGridView1.Columns[dataGridView1.CurrentCell.ColumnIndex].HeaderText;
  29.             if (title.Equals("department"))
  30.             {
  31.                 TextBox autoText = e.Control as TextBox;
  32.                 if (autoText != null)
  33.                 {
  34.                     autoText.AutoCompleteMode = AutoCompleteMode.Suggest;
  35.                     autoText.AutoCompleteSource = AutoCompleteSource.CustomSource;
  36.                     AutoCompleteStringCollection autoCollection = new AutoCompleteStringCollection();
  37.                     autoCollection.Add("开发部");
  38.                     autoCollection.Add("财务部");
  39.                     autoCollection.Add("技术部");
  40.                     autoText.AutoCompleteCustomSource = autoCollection;
  41.                 }
  42.
  43.             }
  44.         }
  45.     }
  46. }
原文链接:pengshiyu.blog.csdn.net/article/details/109661806
