C#编程-118:写入文件StreamWriter类
彭世瑜 发表于 2021/08/14 01:33:33 2021/08/14
【摘要】 using System; using System.Collections.Generic; using System.Linq; using System.Text; using System.IO; namespace StreamWriterTest {   &nbsp...
  1. using System;
  2. using System.Collections.Generic;
  3. using System.Linq;
  4. using System.Text;
  5. using System.IO;
  6. namespace StreamWriterTest
  7. {
  8.     class Program
  9.     {
  10.         static void Main(string[] args)
  11.         {
  12.             string path = @"C:\Users\pengshiyu\Desktop\source\text.txt";
  13.             try
  14.             {
  15.                 //way1:
  16.                 //FileStream fs = new FileStream(path,FileMode.OpenOrCreate);
  17.                 //StreamWriter sw = new StreamWriter(fs);
  18.                 //way2:
  19.                 StreamWriter sw = new StreamWriter(path, false);
  20.                 string mystr = "测试这样话能不能正常显示到文本文件中";
  21.                 sw.Write(mystr);
  22.                 sw.Close();
  23.                 Console.WriteLine("写入完成!");
  24.             }
  25.             catch (Exception ex)
  26.             {
  27.                 Console.WriteLine(ex.Message);
  28.             }
  29.             Console.ReadKey();
  30.         }
  31.     }
  32. }
原文链接:pengshiyu.blog.csdn.net/article/details/81049267
