C#编程-95:分部类partial的使用
彭世瑜 发表于 2021/08/14 00:34:57 2021/08/14
【摘要】 using System; using System.Collections.Generic; using System.Linq; using System.Text;   namespace PartialTest {     partial c...
  1. using System;
  2. using System.Collections.Generic;
  3. using System.Linq;
  4. using System.Text;
  5.
  6. namespace PartialTest
  7. {
  8.     partial class Arithmetic
  9.     {
  10.         public int Factorial(int num)
  11.         {
  12.             int factorial = 1;
  13.             for (int i = num; i > 0; i--)
  14.             {
  15.                 factorial *= i;
  16.             }
  17.             return factorial;
  18.         }
  19.     }
  20.     partial class Arithmetic
  21.     {
  22.         public int Square(int num)
  23.         {
  24.             return num * num;
  25.         }
  26.     }
  27.     class Program
  28.     {
  29.         static void Main(string[] args)
  30.         {
  31.             Arithmetic a = new Arithmetic();
  32.             int num = 5;
  33.             Console.WriteLine("求 {0} 的阶乘:",num);
  34.             Console.WriteLine(a.Factorial(num));
  35.             Console.WriteLine("求 {0} 的平方:", num);
  36.             Console.WriteLine(a.Square(num));
  37.             Console.ReadKey();
  38.         }
  39.     }
  40. }
原文链接:pengshiyu.blog.csdn.net/article/details/81049229
