C#编程-94:迭代器Iterator简单实例
彭世瑜 发表于 2021/08/13 23:49:06 2021/08/13
【摘要】 using System; using System.Collections; using System.Collections.Generic; using System.Linq; using System.Text;   namespace IEnumerable...
  1. using System;
  2. using System.Collections;
  3. using System.Collections.Generic;
  4. using System.Linq;
  5. using System.Text;
  6.
  7. namespace IEnumerableTest
  8. {
  9.     class Program
  10.     {
  11.         public static IEnumerable GetNextValue()
  12.         {
  13.             yield return "111111";
  14.             yield return "222222";
  15.             yield return "333333";
  16.             yield return "444444";
  17.             yield break;
  18.             yield return "555555";
  19.         }
  20.         static void Main(string[] args)
  21.         {
  22.             Console.WriteLine("===迭代成员===");
  23.             foreach (string item in GetNextValue())
  24.             {
  25.                 Console.WriteLine(item);
  26.             }
  27.
  28.             Console.WriteLine("===迭代类===");
  29.             Months months = new Months();
  30.             foreach (string item in months)
  31.             {
  32.                 Console.WriteLine(item);
  33.             }
  34.             Console.ReadKey();
  35.         }
  36.     }
  37.
  38.     class Months : IEnumerable
  39.     {
  40.         string[] months = { "January","February","March","April","May","June","July","August","September","October","November","December"};
  41.         public IEnumerator GetEnumerator()
  42.         {
  43.             for (int i = 0; i < months.Length; i++)
  44.             {
  45.                 yield return months[i];
  46.             }
  47.         }
  48.     }
  49. }
原文链接:pengshiyu.blog.csdn.net/article/details/81049244
