C#编程-116:获取指定目录下的所有文件及文件夹
彭世瑜 发表于 2021/08/14 01:31:47 2021/08/14
【摘要】 using System; using System.Collections.Generic; using System.Linq; using System.Text; using System.IO; namespace GetFiles {     c...
  1. using System;
  2. using System.Collections.Generic;
  3. using System.Linq;
  4. using System.Text;
  5. using System.IO;
  6. namespace GetFiles
  7. {
  8.     class Program
  9.     {
  10.         static void Main(string[] args)
  11.         {
  12.             string path = @"C:\Users\pengshiyu\Desktop\source";
  13.
  14.             if (Directory.Exists(path))
  15.             {
  16.                 string[] files = Directory.GetFiles(path);
  17.                 string[] folders = Directory.GetDirectories(path);
  18.                 Console.WriteLine("获取所有文件:");
  19.                 foreach (string file in files)
  20.                 {
  21.                     Console.WriteLine(file);
  22.                 }
  23.                 Console.WriteLine("获取所有文件夹:");
  24.                 foreach (string folder in folders)
  25.                 {
  26.                     Console.WriteLine(folder);
  27.                 }
  28.             }
  29.             else
  30.             {
  31.                 Console.WriteLine("文件夹不存在!");
  32.             }
  33.             Console.ReadKey();
  34.         }
  35.     }
  36. }
原文链接:pengshiyu.blog.csdn.net/article/details/81049254
