C#编程-122:文件夹选择之FolderBrowserDialog控件_彭世瑜_新浪博客
彭世瑜 发表于 2021/08/14 01:53:27 2021/08/14
【摘要】 using System; using System.Collections.Generic; using System.ComponentModel; using System.Data; using System.Drawing; using System.Linq; using ...
  1. using System;
  2. using System.Collections.Generic;
  3. using System.ComponentModel;
  4. using System.Data;
  5. using System.Drawing;
  6. using System.Linq;
  7. using System.Text;
  8. using System.Windows.Forms;
  9. using System.IO;
  10. namespace FolderBrowserDialogTest
  11. {
  12.     public partial class Form1 : Form
  13.     {
  14.         public Form1()
  15.         {
  16.             InitializeComponent();
  17.         }
  18.
  19.         private void btnTxt_Click(object sender, EventArgs e)
  20.         {
  21.             folderBrowserDialog1.Description = "请选择一个包含txt的文件夹";
  22.             folderBrowserDialog1.RootFolder = Environment.SpecialFolder.Desktop;
  23.             folderBrowserDialog1.ShowNewFolderButton = false;
  24.             if (folderBrowserDialog1.ShowDialog() == DialogResult.OK)
  25.             {
  26.                 string folderPath = folderBrowserDialog1.SelectedPath;
  27.                 string[] files = Directory.GetFiles(folderPath);
  28.                 foreach (string str in files)
  29.                 {
  30.                     if (str.Substring(str.LastIndexOf('.') + 1).ToLower() == "txt")
  31.                     {
  32.                         richTextBox1.AppendText(str + "\n");
  33.                     }
  34.                 }
  35.             }
  36.         }
  37.
  38.         private void btnDoc_Click(object sender, EventArgs e)
  39.         {
  40.             folderBrowserDialog1.Description = "请选择一个包含doc的文件夹";
  41.             folderBrowserDialog1.RootFolder = Environment.SpecialFolder.Desktop;
  42.             folderBrowserDialog1.ShowNewFolderButton = true;
  43.             if (folderBrowserDialog1.ShowDialog() == DialogResult.OK)
  44.             {
  45.                 string folderPath = folderBrowserDialog1.SelectedPath;
  46.                 string[] files = Directory.GetFiles(folderPath);
  47.                 foreach (string str in files)
  48.                 {
  49.                     if (str.Substring(str.LastIndexOf('.') + 1).ToLower() == "doc")
  50.                     {
  51.                         richTextBox1.AppendText(str + "\n");
  52.                     }
  53.                 }
  54.             }
  55.         }
  56.     }
  57. }
原文链接:pengshiyu.blog.csdn.net/article/details/109661875
