C#编程-123:文件监控之FileSystemWatcher控件_彭世瑜_新浪博客
彭世瑜 发表于 2021/08/14 00:51:45 2021/08/14
【摘要】 using System; using System.Collections.Generic; using System.ComponentModel; using System.Data; using System.Drawing; using System.Linq; using ...
  1. using System;
  2. using System.Collections.Generic;
  3. using System.ComponentModel;
  4. using System.Data;
  5. using System.Drawing;
  6. using System.Linq;
  7. using System.Text;
  8. using System.Windows.Forms;
  9. using System.IO;
  10. namespace FileSystemWatcherTest
  11. {
  12.     public partial class Form1 : Form
  13.     {
  14.         public Form1()
  15.         {
  16.             InitializeComponent();
  17.         }
  18.
  19.         private void button1_Click(object sender, EventArgs e)
  20.         {
  21.             if (fileSystemWatcher1.EnableRaisingEvents)
  22.             {
  23.                 fileSystemWatcher1.EnableRaisingEvents = false;
  24.                 button1.Text = "启 动";
  25.             }
  26.             else
  27.             {
  28.                 fileSystemWatcher1.EnableRaisingEvents = true;
  29.                 button1.Text = "停 止";
  30.             }
  31.         }
  32.
  33.         private void Form1_Load(object sender, EventArgs e)
  34.         {
  35.             fileSystemWatcher1.EnableRaisingEvents = false;
  36.             fileSystemWatcher1.Path = @"C:\Users\pengshiyu\Desktop\source";
  37.             fileSystemWatcher1.Filter = "*.*";
  38.             fileSystemWatcher1.IncludeSubdirectories = true;
  39.             fileSystemWatcher1.NotifyFilter = NotifyFilters.Attributes | NotifyFilters.CreationTime | NotifyFilters.DirectoryName | NotifyFilters.FileName;
  40.             textBox1.Text = "";
  41.         }
  42.
  43.         private void fileSystemWatcher1_Changed(object sender, FileSystemEventArgs e)
  44.         {
  45.             textBox1.AppendText(DateTime.Now.ToString()+"文件被修改"+e.Name+Environment.NewLine);
  46.         }
  47.
  48.         private void fileSystemWatcher1_Created(object sender, FileSystemEventArgs e)
  49.         {
  50.             textBox1.AppendText(DateTime.Now.ToString() + "文件被创建" +e.Name+ Environment.NewLine);
  51.         }
  52.
  53.         private void fileSystemWatcher1_Deleted(object sender, FileSystemEventArgs e)
  54.         {
  55.             textBox1.AppendText(DateTime.Now.ToString() + "文件被删除" + Environment.NewLine);
  56.         }
  57.
  58.         private void fileSystemWatcher1_Renamed(object sender, RenamedEventArgs e)
  59.         {
  60.             textBox1.AppendText(DateTime.Now.ToString() + "文件被重命名" + Environment.NewLine);
  61.         }
  62.     }
  63. }
补充:
textBox1.AppendText()方法,可以使得光标一直处于文本框最后。。。
原文链接:pengshiyu.blog.csdn.net/article/details/109661878
