C#编程-142:新增注册表_彭世瑜_新浪博客
彭世瑜 发表于 2021/08/14 01:24:24 2021/08/14
【摘要】 using System; using System.Windows.Forms; using Microsoft.Win32; namespace RegistryTestSetValue {     public&...
C#编程-142:新增注册表
C#编程-142:新增注册表
  1. using System;
  2. using System.Windows.Forms;
  3. using Microsoft.Win32;
  4. namespace RegistryTestSetValue
  5. {
  6.     public partial class Form1 : Form
  7.     {
  8.         public Form1()
  9.         {
  10.             InitializeComponent();
  11.         }
  12.
  13.         private void btnSetup_Click(object sender, EventArgs e)
  14.         {
  15.             if (txtKey.Text == "") {
  16.                 MessageBox.Show("输入错误");
  17.                 return ;}
  18.             RegistryKey hklm = Registry.LocalMachine;
  19.             RegistryKey sys = hklm.OpenSubKey("System",true);
  20.             RegistryKey temp = sys.CreateSubKey(txtKey.Text);
  21.             temp.SetValue(txtName.Text,txtValue.Text);
  22.             //listBox1.Items.Clear();
  23.             foreach (string site in sys.GetSubKeyNames())
  24.             {
  25.                 if (txtKey.Text == site)
  26.                 {
  27.                     RegistryKey sitekey = sys.OpenSubKey(site);
  28.                     foreach (string svalue in sitekey.GetSubKeyNames())
  29.                     {
  30.                         listBox1.Items.Add(sitekey+svalue + " : " + sitekey.GetValue(svalue));
  31.                     }
  32.                 }
  33.             }
  34.         }
  35.
  36.         private void Form1_Load(object sender, EventArgs e)
  37.         {
  38.             RegistryKey hklm = Registry.LocalMachine;
  39.             RegistryKey sys = hklm.OpenSubKey("System");
  40.             listBox1.Items.Clear();
  41.             foreach (string subkey in sys.GetSubKeyNames())
  42.             {
  43.                 listBox1.Items.Add(subkey);
  44.             }
  45.         }
  46.     }
  47. }
原文链接:pengshiyu.blog.csdn.net/article/details/109661913
