Mac pip按照提示更新没有成功
彭世瑜 发表于 2021/08/13 23:26:25 2021/08/13
【摘要】 pip报错,按照提示更新没有成功 You are using pip version 9.0.1, however version 9.0.3 is available. You should consider upgrading via the 'pip install --upgrade pip' command. 12 解决办法: 1、下载pip http...
pip报错,按照提示更新没有成功
解决办法:
1、下载pip
https://pypi.python.org/pypi/pip
2、解压安装
sudo python setup.py install
3、查看版本
pip --version
参考:
1. You are using pip version 9.0.1, however version 9.0.3 is available.
原文链接:pengshiyu.blog.csdn.net/article/details/79837199
