macOS sublime Text 3快速插入时间
彭世瑜 发表于 2021/08/14 01:40:20 2021/08/14
【摘要】 安装插件 插件下载地址:https://github.com/kairyou/SublimeInsertDatetime 不同平台路径不一样,找到 Sublime Text安装目录,将insert_datetime.py放入Packages下就行 insert_datetime.py 源码备份,如果github打不开可以保存下面的代码 # coding=utf-...
安装插件
# coding=utf-8
# 比较版本号
# import sys;print(sys.version_info[:2] < (3,0))
# import platform;print(platform.python_version() < '3.0')
# print(int(sublime.version()) < 3000)
import sys, sublime_plugin, datetime
class insertDatetimeCommand(sublime_plugin.TextCommand):
  def run(self, edit, format): timestamp = datetime.datetime.now() if format == 'ymd': # yyyy-mm-dd timestamp = timestamp.strftime('%Y-%m-%d') elif format == 'ymdhms': # %X = %H:%M:%S timestamp = timestamp.strftime('%Y-%m-%d %X') else: # format == "xxx" # 2012-02-18 13:17:28.047000 #timestamp = datetime.datetime.now().isoformat(' ') # Sat Feb 18 13:20:41 2012 #timestamp = datetime.datetime.now().ctime() # 数字变为字符串 str(xx),字符串变为数字 int(string) timestamp = int(timestamp.strftime("%w")) week = { 1 : '一', 2 : '二', 3 : '三', 4 : '四', 5 : '五', 6 : '六', 7 : '日' } timestamp = '星期' + week[timestamp] # print(sys.version_info[:2] < (3,0)) if sys.version_info[:2] < (3,0): ## 中文要指定: coding=utf-8 | gbk ,再decode timestamp = timestamp.decode('utf-8') # else: # timestamp = timestamp.encode('utf-8').decode('utf-8') #for region in the selection for r in self.view.sel(): #put in the timestamp #(if text is selected, it'll be replaced in an intuitive fashion) self.view.erase(edit, r) self.view.insert(edit, r.begin(), timestamp)
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
设置快捷键
快捷键绑定Preference → Key Bindings - User
[ { "keys": ["f5"], "command": "insert_datetime", "args": {"format": "ymd"} }, { "keys": ["alt+f5"], "command": "insert_datetime", "args": {"format": "ymdhms"} }, { "keys": ["ctrl+f5"], "command": "insert_datetime", "args": {"format": "E"} }
重启生效
时间格式:
yyyy-MM-dd: F5
yyyy-MM-dd hh:mm:ss: alt+F5
星期E: ctrl+F5
参考
原文链接:pengshiyu.blog.csdn.net/article/details/80264168
