Python编程:协程async和await
彭世瑜 发表于 2021/08/13 23:16:31 2021/08/13
【摘要】 Python 3.5 把@asyncio.coroutine替换为async; 把yield from替换为await12 用asyncio提供的@asyncio.coroutine可以把一个generator标记为coroutine类型,然后在coroutine内部用yield from调用另一个coroutine实现异步操作。 以下两种写法等价 @async...
Python 3.5
把yield from替换为await
以下两种写法等价
@asyncio.coroutine
def hello(): print("Hello world!") r = yield from asyncio.sleep(1) print("Hello again!")
python3.5
async def hello(): print("Hello world!") r = await asyncio.sleep(1) print("Hello again!")
协程示例
import asyncio
import time
now = lambda : time.time()
async def hello(): print("hello") await asyncio.sleep(2) return "done"
start = now()
# 协程对象
h1 = hello()
h2 = hello()
h3 = hello()
# 创建一个事件loop
loop = asyncio.get_event_loop()
# 任务(task)对象
tasks = [ asyncio.ensure_future(h1), asyncio.ensure_future(h2), asyncio.ensure_future(h3),
# 将协程加入到事件循环loop
loop.run_until_complete(asyncio.wait(tasks))
for task in tasks: print(task.result())
print(now()-start)
hello
hello
hello
done
done
done
2.005011796951294
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
参考
  1. 廖雪峰pyhton -async/await
  2. python中重要的模块–asyncio
原文链接:pengshiyu.blog.csdn.net/article/details/80762698
评论(0
