Java: Hadoop文件系统的读写操作
彭世瑜 发表于 2021/08/13 23:28:15 2021/08/13
【摘要】 所需jar包路径: hadoop-2.8.5/share/hadoop/common hadoop-2.8.5/share/hadoop/common/bin hadoop-2.8.5/share/hadoop/hdfs hadoop-2.8.5/share/hadoop/hdfs/bin 12345 java代码实例 import org.apache.had...
所需jar包路径:
java代码实例
import org.apache.hadoop.conf.Configuration;
import org.apache.hadoop.fs.FileSystem;
import org.apache.hadoop.fs.Path;
import org.apache.hadoop.io.IOUtils;
import java.io.*;
import java.net.URI;
import java.net.URISyntaxException;
 * HDFS操作,需要导入common和hdsf文件夹下的jar
public class HDSFDemo { private FileSystem fs = null; HDSFDemo() throws IOException, URISyntaxException, InterruptedException { Configuration conf = new Configuration(); fs = FileSystem.get(new URI("hdfs://master:9000"), conf, "root"); } /** * 下载文件 * * @throws IOException */ public void download() throws IOException { InputStream in = fs.open(new Path("/java")); OutputStream out = new FileOutputStream("/Users/Desktop"); IOUtils.copyBytes(in, out, 4096, true); } /** * 上传文件 * * @throws IOException */ public void upload() throws IOException { System.out.println("开始上传..."); InputStream in = new FileInputStream("/Users/Desktop/compare.py"); OutputStream out = this.fs.create(new Path("/compare.py")); IOUtils.copyBytes(in, out, 4096, true); } /** * 删除文件 * * @throws IOException */ public void delete() throws IOException { boolean ret = this.fs.delete(new Path("/java"), true); System.out.println("文件删除结果:" + ret); } /** * 创建文件夹 * * @throws IOException */ public void mkdir() throws IOException { boolean ret = this.fs.mkdirs(new Path("/temp")); System.out.println("文件创建成功:" + ret); } public static void main(String[] args) throws URISyntaxException, IOException, InterruptedException { HDSFDemo hdfs = new HDSFDemo(); hdfs.upload(); }
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
备注:
URI的端口号一定要和配置文件中的端口号一致
问题:
log4j:WARN Please initialize the log4j system properly
可参考:log4j:WARN Please initialize the log4j system properly 问题解决
原文链接:pengshiyu.blog.csdn.net/article/details/84405252
