本地部署easy-mock生成模拟数据
彭世瑜 发表于 2021/08/13 23:58:20 2021/08/13
【摘要】 Easy Mock 是一个可视化,并且能快速生成模拟数据的持久化服务 github https://github.com/easy-mock/easy-mock 1、配置环境 缺一不可,重点是版本对应 Node.js (v8.x, v10.x is not supported)MongoDB (>= v3.4)Redis(>= v4.0) # mo...
1、配置环境
缺一不可,重点是版本对应
  1. Node.js (v8.x, v10.x is not supported)
  2. MongoDB (>= v3.4)
  3. Redis(>= v4.0)
# mongod --version
db version v3.4.20
# redis-cli --version
redis-cli 3.0.2
# node -v
v8.15.1
2、下载安装
$ git clone https://github.com/easy-mock/easy-mock.git
$ cd easy-mock && npm install
配置文件说明
打开项目下的config/default.json文件,如无特别需要就不用改了
  "port": 7300,//easymock项目启动的端口
  "host": "0.0.0.0",
  "pageSize": 30,
  "proxy": false,
  "db": "mongodb://localhost/easy-mock",// 不需要自己新建数据库,在启动的easymock新建接口即可
  "unsplashClientId": "",
  "redis": { "port": 6379,//redis端口 "host": "localhost"
  "blackList": { "projects": [], // projectId,例:"5a4495e16ef711102113e500" "ips": [] // ip,例:"127.0.0.1"
  "rateLimit": { // https://github.com/koajs/ratelimit "max": 1000, "duration": 1000
  "jwt": { "expire": "14 days", "secret": "shared-secret"
  "upload": { "types": [".jpg", ".jpeg", ".png", ".gif", ".json", ".yml", ".yaml"], "size": 5242880, "dir": "../public/upload", "expire": { "types": [".json", ".yml", ".yaml"], "day": -1 }
  "fe": { "copyright": "", "storageNamespace": "easy-mock_", "timeout": 25000, "publicPath": "/dist/"
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
3、运行
$ npm run build
$ npm run start
访问:http://127.0.0.1:7300
参考
easy-mock 本地部署(挤需体验三番钟,里造会干我一样,爱象节款mock)
原文链接:pengshiyu.blog.csdn.net/article/details/88839508
