Elasticsearch添加拼音搜索支持
彭世瑜 发表于 2021/08/13 23:58:37 2021/08/13
【摘要】 一份不错的资料 ELASTIC 搜索开发实战 一、安装插件 拼音分词扩展elasticsearch-analysis-pinyin安装 文档: https://github.com/medcl/elasticsearch-analysis-pinyin 二、新建索引添加拼音支持 <index> 替换为 实际 index <type> 替...
一份不错的资料
ELASTIC 搜索开发实战
一、安装插件
二、新建索引添加拼音支持
<type> 替换为 实际 type
PUT <index>
  "settings" : { "analysis" : { "analyzer" : { "pinyin_analyzer" : { "tokenizer" : "my_pinyin" } }, "tokenizer" : { "my_pinyin" : { "type" : "pinyin", "keep_first_letter":false, "keep_separate_first_letter" : false, "keep_full_pinyin" : true, "keep_original" : false, "limit_first_letter_length" : 16, "lowercase" : true } } } }, "mappings": { "<type>": { "properties": { "name": { "type": "text", "index": true, "fields":{ "pinyin":{ "type":"text", "analyzer":"pinyin_analyzer" } } }, "link": { "type": "keyword", "index": false }, "id": { "type": "long" }, "update_time": { "type": "date", "format": "yyyy-MM-dd HH:mm:ss||yyyy-MM-dd||epoch_millis" } } }
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
分词测试
GET <index>/_analyze
  "field": "name.pinyin",
  "text": "内蒙古"
返回
  "tokens": [ { "token": "nei", "start_offset": 0, "end_offset": 1, "type": "word", "position": 0 }, { "token": "meng", "start_offset": 1, "end_offset": 2, "type": "word", "position": 1 }, { "token": "gu", "start_offset": 2, "end_offset": 3, "type": "word", "position": 2 }
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
二、已有索引添加拼音支持
1、新建索引
PUT <index>
  "mappings": { "<type>": { "properties": { "name": { "type": "keyword", "index": true }, "link": { "type": "keyword", "index": false }, "id": { "type": "long" }, "update_time": { "type": "date", "format": "yyyy-MM-dd HH:mm:ss||yyyy-MM-dd||epoch_millis" } } }
2、设置拼音分词器
POST  <index>/_close
PUT <index>/_settings
  "index": { "analysis": { "analyzer": { "pinyin_analyzer": { "tokenizer": "my_pinyin" } }, "tokenizer": { "my_pinyin": { "type": "pinyin", "keep_first_letter": true, "keep_separate_first_letter": true, "keep_full_pinyin": true, "keep_original": false, "limit_first_letter_length": 16, "lowercase": true } } }
POST  <index>/_open
  • 26
  • 27
3、修改mapping,添加拼音分词器
PUT <index>/<type>/_mapping
  "<type>": { "properties": { "name": { "type": "keyword", "index": true, "fields":{ "pinyin":{ "type":"text", "analyzer":"pinyin_analyzer" } } }, "link": { "type": "keyword", "index": false }, "id": { "type": "long" }, "update_time": { "type": "date", "format": "yyyy-MM-dd HH:mm:ss||yyyy-MM-dd||epoch_millis" } }
GET <index>/_mapping
# 将当前索引的数据重新替换一下当前索引
POST <index>/_update_by_query?conflicts=proceed
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
4、搜索测试
get <index>/_search
  "query_string": { "fields": [ "name", "name.pinyin" ], "query": "王苏川", "default_operator": "AND"
参考
Elastic 搜索开发实战 拼音处理
原文链接:pengshiyu.blog.csdn.net/article/details/103153614
