Webpack插件使用及热更新打包
彭世瑜 发表于 2021/08/13 23:23:13 2021/08/13
【摘要】 1、HtmlWebpackPlugin 自动生成基本的 html 页面 2、开启文件监听 3、webpack-dev-server热更新 安装依赖 cnpm i html-webpack-plugin webpack-dev-server -D 1 配置文件 1、.babelrc { "presets": [ "@babel/preset-env", ] } 1...
2、开启文件监听
安装依赖
配置文件
1、.babelrc
2、package.json
  "name": "web-demo",
  "version": "1.0.0",
  "description": "",
  "main": "index.js",
  "scripts": { "build": "webpack", "watch": "webpack --watch", "dev": "webpack-dev-server --open"
  "keywords": [],
  "author": "",
  "license": "ISC",
  "devDependencies": { "@babel/core": "^7.9.0", "@babel/preset-env": "^7.9.0", "babel-loader": "^8.1.0", "css-loader": "^3.4.2", "file-loader": "^6.0.0", "html-webpack-plugin": "^4.0.3", "less": "^3.11.1", "less-loader": "^5.0.0", "style-loader": "^1.1.3", "url-loader": "^4.0.0", "webpack": "^4.42.1", "webpack-cli": "^3.3.11", "webpack-dev-server": "^3.10.3"
  • 26
  • 27
  • 28
  • 29
3、webpack.config.js
'use strict'
const path = require('path');
const HtmlWebpackPlugin = require('html-webpack-plugin')
const webpack = require('webpack');
module.exports = { // 文件监听 watch: true, watchOptions: { //默认为空,设置不监听的文件或者文件夹,支持正则匹配 ignored: /node_modules/, //监听到变化发生后会等300ms再去执行,默认300ms aggregateTimeout: 300, //设置轮询文件是否变化时间,默认每秒问1000次 poll: 1000 }, // 打包入口 entry: { index: './src/index.js', }, // 指定输出地址及打包出来的文件名 output: { path: path.join(__dirname, 'dist'), filename: 'index.js' }, plugins: [ // 自动生成基本的 html 页面 new HtmlWebpackPlugin({ title: 'leaningwebpack', // 文件的标题 filename: 'webpack-index.html', // 文件名 favicon: 'src/demo.png' // 网页图标 }), // 热更新 new webpack.HotModuleReplacementPlugin() ], devServer: { contentBase: './dist', hot: true }, module: { rules: [ { test: /.js$/, use: 'babel-loader', // 忽略依赖包 exclude: /node_modules/ }, { test: /.css$/, // 执行的时候是先加载css-loader,将css解析好后再将css传递给style-loader use: [ 'style-loader', 'css-loader', ] }, { test: /.less$/, use: [ 'style-loader', 'css-loader', 'less-loader' ] }, { test: /.(jpg|png|gif|jpeg)$/, use: [{ loader: 'url-loader', options: { // 如果图片大小小于这个值,就会被打包为base64格式 limit: 160000, name: 'imgs/[name].[hash].[ext]' } }] } ] }, // 开发环境 mode: 'production',
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
参考
Webpack 实战入门系列(二):插件使用及热更新打包
原文链接:pengshiyu.blog.csdn.net/article/details/105178716
