express使用cros开启跨域访问
彭世瑜 发表于 2021/08/14 00:23:26 2021/08/14
【摘要】 如果跨域,前端直接请求后端数据会报错 Access to XMLHttpRequest at 'http://127.0.0.1:8080/' from origin 'null' has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the r...
如果跨域,前端直接请求后端数据会报错
No 'Access-Control-Allow-Origin' header is present on the requested resource.
项目结构
├── index.html
├── index.js
└── package.json
package.json
  "dependencies": { "cors": "^2.8.5", "express": "^4.17.1"
index.js
var express = require('express')
var cors = require('cors')
var app = express()
app.use(cors())
app.get('/', function (req, res) { res.send("hello")
app.listen(8080, function () { console.log('listening: http://127.0.0.1:8080/')
index.html
<script> var request = new XMLHttpRequest(); request.open('GET', 'http://127.0.0.1:8080', true) request.send(null) request.onreadystatechange = function () { if (request.readyState == 4 && request.status == 200) { console.log(request.responseText); } }
</script>
通过以上代码就可以正常请求获取后台数据了
原文链接:pengshiyu.blog.csdn.net/article/details/105718270
评论(0
