Java:jackson将xml和json转为JavaBean对象
彭世瑜 发表于 2021/08/13 23:35:02 2021/08/13
【摘要】 依赖 <!-- xml => Object --> <dependency> <groupId>com.fasterxml.jackson.dataformat</groupId> <artifactId>jackson-dataformat-xml</artifactId> <ver...
依赖
<dependency> <groupId>com.fasterxml.jackson.dataformat</groupId> <artifactId>jackson-dataformat-xml</artifactId> <version>2.10.1</version>
</dependency>
<dependency> <groupId>org.codehaus.woodstox</groupId> <artifactId>woodstox-core-asl</artifactId> <version>4.4.1</version>
</dependency>
<!-- json => Object -->
<dependency> <groupId>com.fasterxml.jackson.core</groupId> <artifactId>jackson-databind</artifactId> <version>2.10.0</version>
</dependency>
book.xml
<?xml version="1.0" encoding="UTF-8" ?>
<book> <id>1</id> <name>三国演义</name> <author>罗贯中</author>
</book>
book.json
  "id": 1,
  "name": "三国演义",
  "author": "罗贯中"
Book.java
package com.example.demo.pojo;
public class Book { private Integer id; private String name; private String author; public Integer getId() { return id; } public void setId(Integer id) { this.id = id; } public String getName() { return name; } public void setName(String name) { this.name = name; } public String getAuthor() { return author; } public void setAuthor(String author) { this.author = author; } @Override public String toString() { return "Book{" + "id=" + id + ", name='" + name + '\'' + ", author='" + author + '\'' + '}'; }
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
测试类
package com.example.demo;
import com.example.demo.pojo.Book;
import com.fasterxml.jackson.databind.DeserializationFeature;
import com.fasterxml.jackson.databind.ObjectMapper;
import com.fasterxml.jackson.dataformat.xml.JacksonXmlModule;
import com.fasterxml.jackson.dataformat.xml.XmlMapper;
import org.junit.jupiter.api.Test;
import java.io.IOException;
import java.io.InputStream;
public class JacksonTest { @Test public void testParseXml() throws IOException { InputStream input = JacksonTest.class.getResourceAsStream("/book.xml"); JacksonXmlModule module = new JacksonXmlModule(); XmlMapper mapper = new XmlMapper(module); Book book = mapper.readValue(input, Book.class); System.out.println(book); // Book{id=1, name='三国演义', author='罗贯中'} // 转xml String xml = mapper.writeValueAsString(book); System.out.println(xml); // <Book><id>1</id><name>三国演义</name><author>罗贯中</author></Book> } @Test public void testParseJson() throws IOException { InputStream input = JacksonTest.class.getResourceAsStream("/book.json"); ObjectMapper mapper = new ObjectMapper(); // 反序列化时忽略不存在的JavaBean属性 mapper.configure(DeserializationFeature.FAIL_ON_UNKNOWN_PROPERTIES, false); Book book = mapper.readValue(input, Book.class); System.out.println(book); // Book{id=1, name='三国演义', author='罗贯中'} //JavaBean变为JSON String json = mapper.writeValueAsString(book); System.out.println(json); // {"id":1,"name":"三国演义","author":"罗贯中"} }
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
参考
https://www.liaoxuefeng.com/wiki/1252599548343744/1320418596093986
原文链接:pengshiyu.blog.csdn.net/article/details/107605027
