使用NGUI发布apk出错
陈言必行 发表于 2021/08/14 01:30:53 2021/08/14
【摘要】 当前使用NGUI打包文件出错, NGUI 打包出错,,, An asset is marked with HideFlags.DontSave but is included in the build: Asset: 'Library/unity editor resources' (You are probably referencing internal U...
当前使用NGUI打包文件出错,
NGUI 打包出错,,,
(You are probably referencing internal Unity data in your build.)
UnityEditor.HostView:OnGUI()
Building - Failed to write file: 0000000000000000d000000000000000
这错误,,,
原因是Unity 字体和NGUI字体不匹配,,更换自己下载的字体包,或者更换NGUI版本,,或者试着降低Unity版本,,,就OK了,,
文章来源: czhenya.blog.csdn.net,作者:陈言必行,版权归原作者所有,如需转载,请联系作者。
原文链接:czhenya.blog.csdn.net/article/details/77986184
