Nginx转发到Flask应用scheme获取不到https
彭世瑜 发表于 2021/08/14 00:47:34 2021/08/14
【摘要】 通过Nginx配置转发到Flask应用 server { listen 80; server_name _; access_log /var/log/nginx/access.log; error_log /var/log/nginx/error.log; location / { proxy_pass http://127.0.0.1:8000/; proxy_...
通过Nginx配置转发到Flask应用
server { listen 80; server_name _; access_log  /var/log/nginx/access.log; error_log  /var/log/nginx/error.log; location / { proxy_pass http://127.0.0.1:8000/; proxy_redirect off; proxy_set_header   Host $host; proxy_set_header   X-Real-IP $remote_addr; proxy_set_header   X-Forwarded-For $proxy_add_x_forwarded_for; proxy_set_header   X-Forwarded-Proto $scheme; }
配置中明明已经有$scheme 字段配置了,Flask中只能获取到http,而不是https
还需要在Flask应用中加入以下代码才能生效
from werkzeug.middleware.proxy_fix import ProxyFix
app.wsgi_app = ProxyFix(app.wsgi_app, x_proto=1, x_host=1)
参考
https://stackoverflow.com/questions/23347387/x-forwarded-proto-and-flask
https://flask.palletsprojects.com/en/1.1.x/deploying/wsgi-standalone/#proxy-setups
原文链接:pengshiyu.blog.csdn.net/article/details/109028664
