ValueError: Sample larger than population or is negative
彭世瑜 发表于 2021/08/13 23:51:58 2021/08/13
【摘要】 选取样本函数random.sample 正确使用示例 # -*- coding: utf-8 -*- import random lst = [1, 2, 3] ret = random.sample(lst, 2) print(ret) # [3, 2] 12345678 如果选取的数量比全量数据多,就会报错 # -*- coding: utf-8 -*-...
选取样本函数random.sample
正确使用示例
import random
lst = [1, 2, 3]
print(ret)
# [3, 2]
如果选取的数量比全量数据多,就会报错
import random
lst = [1, 2, 3]
ret = random.sample(lst, 4)
print(ret)
# ValueError: Sample larger than population or is negative
原文链接:pengshiyu.blog.csdn.net/article/details/111594983
