Java:MyBatis-Plus-AutoGenerator代码生成器
彭世瑜 发表于 2021/08/14 01:08:11 2021/08/14
【摘要】 文档:https://baomidou.com/guide/generator.html 配置参数:https://baomidou.com/config/generator-config.html 依赖 <!--代码生成器--> <dependency> <groupId>com.baomidou</groupId&g...
依赖
<!--代码生成器-->
<dependency>
  <groupId>com.baomidou</groupId> <artifactId>mybatis-plus-generator</artifactId> <version>3.4.0</version>
</dependency>
<!--模板引擎 依赖-->
<dependency> <groupId>org.apache.velocity</groupId> <artifactId>velocity-engine-core</artifactId> <version>2.2</version>
</dependency>
<!-- 数据库驱动 -->
<dependency> <groupId>mysql</groupId> <artifactId>mysql-connector-java</artifactId> <version>8.0.22</version>
</dependency>
<dependency> <groupId>org.projectlombok</groupId> <artifactId>lombok</artifactId> <version>1.18.12</version> <scope>provided</scope>
</dependency>
  • 26
  • 27
最简单的代码示例
package com.demo.mybatis;
import com.baomidou.mybatisplus.annotation.FieldFill;
import com.baomidou.mybatisplus.generator.AutoGenerator;
import com.baomidou.mybatisplus.generator.config.DataSourceConfig;
import com.baomidou.mybatisplus.generator.config.GlobalConfig;
import com.baomidou.mybatisplus.generator.config.PackageConfig;
import com.baomidou.mybatisplus.generator.config.StrategyConfig;
import com.baomidou.mybatisplus.generator.config.po.TableFill;
import com.baomidou.mybatisplus.generator.config.rules.NamingStrategy;
import java.util.ArrayList;
 * 自动生成类
public class CodeGenerator { /** * 必要的配置 */ // 生成代码的表名 private static final String TABLE_NAME = "table_person"; // 数据库相关配置 private static final String JDBC_URL = "jdbc:mysql://localhost:3306/data?useUnicode=true&useSSL=false&characterEncoding=utf8"; private static final String DRIVER_NAME = "com.mysql.cj.jdbc.Driver"; private static final String USERNAME = "root"; private static final String PASSWORD = "123456"; // 注释显示的作者 private static final String AUTHOR = "mouday"; // 代码生成指定包名 private static final String PACKAGE_NAME = "com.example"; public static void main(String[] args) { // ======= 全局配置 ======= GlobalConfig globalConfig = new GlobalConfig(); String dir = System.getProperty("user.dir"); globalConfig.setOutputDir(dir + "/src/main/java"); // 输出目录 globalConfig.setOpen(false); // 不打开输出目录 globalConfig.setAuthor(AUTHOR); // 开发人员 // ======= 数据源配置 ======= DataSourceConfig dataSource = new DataSourceConfig(); dataSource.setDriverName(DRIVER_NAME); dataSource.setUsername(USERNAME); dataSource.setPassword(PASSWORD); dataSource.setUrl(JDBC_URL); // ======= 包配置 ======= PackageConfig packageConfig = new PackageConfig(); packageConfig.setParent(PACKAGE_NAME); // ======= 策略配置 ======= StrategyConfig strategy = new StrategyConfig(); strategy.setNaming(NamingStrategy.underline_to_camel); // 表名 strategy.setColumnNaming(NamingStrategy.underline_to_camel); // 字段 strategy.setInclude(TABLE_NAME); // 需要生成的表 strategy.setEntityLombokModel(true); // lombok模型 strategy.setRestControllerStyle(true); // Rest控制器 // 自动填充配置 TableFill createTime = new TableFill("create_time", FieldFill.INSERT); TableFill updateTime = new TableFill("update_time", FieldFill.UPDATE); ArrayList<TableFill> tableFills = new ArrayList<>(); tableFills.add(createTime); tableFills.add(updateTime); strategy.setTableFillList(tableFills); // ======= 执行生成 ======= AutoGenerator autoGenerator = new AutoGenerator(); autoGenerator.setGlobalConfig(globalConfig); autoGenerator.setDataSource(dataSource); autoGenerator.setPackageInfo(packageConfig); autoGenerator.setStrategy(strategy); autoGenerator.execute(); }
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
原文链接:pengshiyu.blog.csdn.net/article/details/111644828
