Python: flask-socketio使用Websocket协议进行通讯
彭世瑜 发表于 2021/08/14 01:06:16 2021/08/14
【摘要】 文档: PyPI: https://pypi.org/project/Flask-SocketIO/Github: https://github.com/miguelgrinberg/Flask-SocketIOdoc: https://flask-socketio.readthedocs.iosocket.io: https://socket.io/ 安装 pi...
文档:
安装
pip install flask-socketio gevent-websocket
代码实例
from flask import Flask, render_template, request
from flask_socketio import SocketIO
app = Flask(__name__)
app.config['SECRET_KEY'] = 'secret!'
app.jinja_env.auto_reload = True
socketio = SocketIO(app)
@app.route('/')
def index(): return render_template('index.html')
@app.route('/send_all')
def send_all(): """ 广播 :return: """ message = request.args.get('message') socketio.send(message) return {'status': 'ok'}
@app.route('/send')
def send_message(): """ 单独发送 :return: """ sid = request.args.get('sid') message = request.args.get('message') socketio.send(message, to=sid) return {'status': 'ok'}
@socketio.on('connect')
def connect(): print('connect') socketio.send({'sid': request.sid})
@socketio.on('disconnect')
def disconnect(): print('disconnect')
@socketio.on('message')
def handle_message(data): print(data) socketio.send({'data': data})
if __name__ == '__main__': socketio.run(app, debug=True)
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
Http 发送测试请求
import requests
params = { 'sid': 'm4AymrH2TIFHCcQNAAAF', 'message': 'send'
res = requests.get('http://localhost:5000/send', params=params)
print(res.text)
params = { 'message': 'send_all'
res = requests.get('http://localhost:5000/send_all', params=params)
print(res.text)
原文链接:pengshiyu.blog.csdn.net/article/details/116000667
